10-28-2001, 05:31 | #1 (permalink) |
Banned Join Date: Oct 2001 Location: JMB Age: 49
Member: 6919 Status: Offline Thanks Meter: 12 | 3210 signal prb,, |
10-29-2001, 09:19 | #4 (permalink) |
Junior Member Join Date: Aug 2001 Location: bulgaria
Member: 5770 Status: Offline Thanks Meter: 0 | Do not make this mistake to reflash phone ... problem is hardware ... resolder with hot air gun power amplifiers ... if not working ... desolder 71 mhz filter located bottom right on board ... (black keramic) and with wires put INPUT to OUTPUT... have 2 inputs and 2 OUTPUTS ... u need 2 wires |
10-29-2001, 16:15 | #5 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Czech Republic
Member: 4246 Status: Offline Thanks Meter: 9 | But it can be software error,too.<br />I had 3210 4.41 with falling signal.<br />I reflasher phone with same version and language pack and all was ok.<br />full flash is from 0020000-0040000 Regards |
10-29-2001, 20:15 | #7 (permalink) |
No Life Poster Join Date: Dec 2000 Location: Slovakia, Brezno
Member: 2721 Status: Offline Thanks Meter: 23 | mudboy solution is good, if someone flash phone with another FW version or language pack. But how to get now original FW version an language pack? [ 29 October 2001: Message edited by: ARS ]</p> |
10-29-2001, 20:55 | #8 (permalink) |
No Life Poster Join Date: Mar 2001 Location: Some where around the world.
Member: 3845 Status: Offline Thanks Meter: 2 | Hi,<br />Is a hardware problem.Try Victor Levunliev solution.If cannot try my solution reflow the cobba ic with hotair gun.This 2 solution 80% work with most 3210 phone.<br /> <img src="wink.gif" border="0"> <img src="wink.gif" border="0"> <img src="wink.gif" border="0"> |
10-29-2001, 20:58 | #9 (permalink) |
Member: 3845 Status: Offline Thanks Meter: 2 | Hi,<br />Becareful most of the new version of 3210 cobba ic have black glue.You have to remove but it is very hard remove black glue. <img src="mad.gif" border="0"> <img src="mad.gif" border="0"> <img src="mad.gif" border="0"> |
10-30-2001, 12:10 | #11 (permalink) |
Freak Poster Join Date: Mar 2001 Location: Australia
Member: 3815 Status: Offline Thanks Meter: 2 | i have a water damaged 3210 which has no reception now but i can still turn it on. occasionally, it gets reception for 1sec then none. would it help if i use full flash or it is definitely hardware problem? <img src="frown.gif" border="0"> |
11-04-2001, 03:08 | #14 (permalink) |
No Life Poster Join Date: Sep 2000 Location: Philippines
Member: 2034 Status: Offline Thanks Meter: 24 | [quote]Originally posted by Cad:<br /><strong>all you people saying this is hardware problem? The fone is probably blacklisted on the network</strong><hr></blockquote> The phone is not 100% blacklisted on the network. Try reading on the problem. They say phone registers to the network after a few seconds it dissappears. Does this mean blacklisted, nop i bet you its not blacklisted alright.. To TRAFIX try reading the 4th post you'll see the solution. I have tried it for three times now it worked 100% percent. Software solutions are secondary solution in repairing phones especially nokia units. Dont rely much on the softwares because these are lone controller of the systems secondary to hardwares. Yup ill tell you its hardware problem. REGards! |
11-04-2001, 06:23 | #15 (permalink) |
Member: 6919 Status: Offline Thanks Meter: 12 | Hi victor<br />iam replying to u about the answer that u have given me on the gsmcity.de fourm.. about my 3210 <br /> the original your ans is following : <br />"Do not make this mistake to reflash phone ...<br />problem is hardware ... resolder with hot air gun power amplifiers ... if not working ... desolder 71 mhz filter located bottom right on board ... (black keramic) and with wires put INPUT to OUTPUT... have 2 inputs and 2 OUTPUTS ... u need 2 wires " i have resolder the power amplifiers... but not worked... now i have desolder the 71 MHz filter but could not locate which two are in put and which are input...i mean 1 and 2 are in put or i and 3 are input ... since i have checked that 1 and 3 are short... counting form bottom to the top... do i count from top to bottom.. or bottom to top..<br />but the phone is still powered on.. although the 71 Mhz is out...<br />please quide me thanks<br />i have tried to email u but the address doesnot exist so i put that here... |
ke770 signal prb | khurram_player | LG | 1 | 12-07-2008 12:38 |
3210 signal poor | hooi76 | Nokia Hardware & Hardware Repair | 6 | 12-14-2001 11:37 |
nokia 3210 signal | GsMen | Nokia Hardware & Hardware Repair | 3 | 11-04-2001 19:10 |
3210 Signal Boost | complicity | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 09-03-2001 22:44 |
nokia 3210 signal coming and going | Blartiartfast | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 05-29-2001 23:57 |
