01-05-2001, 14:01 | #1 (permalink) |
Temporary banned !! Join Date: Oct 2000 Location: Sky phone
Member: 2273 Status: Offline Thanks Meter: 0 | 3210 v6.00 Flash ID: 00898890 Loading Boot loader Boot Loader is Ready Flash ID: 00898890 Loading flash Loader Flash Loader Init Error TX=0 When I try to flash the phone I got message: Loading Boot loader Boot Loader is Ready Flash ID: 00898890 Loading flash Loader Flash erasing error I tryed with manny different f_loaders, but with no success.. I also noticed that other people have the same problem... My conclusion is that we need another f_loader. Is there anyone who successfully flashed Nokia with this kind of flash chip ? (it is Intel F160B3TA) regards, Boca |
01-05-2001, 23:35 | #2 (permalink) |
Freak Poster Join Date: Sep 1999 Location: UK
Member: 498 Status: Offline Thanks Meter: 6 | Hi, I think you need special FLASHER+TDCRYPT security box to flash erase. You must have already flashed this nokia. So without this box you can't erase flash! Tell me if I'm wrong... Regards Dave |
01-06-2001, 00:53 | #3 (permalink) | |
Freak Poster Join Date: Jun 2000
Member: 1641 Status: Offline Thanks Meter: 54 | hi, yes, you are wrong, many people had successful with this. problem f_loader.bin. b.r. LIKI999. Quote:
01-06-2001, 15:23 | #4 (permalink) |
Freak Poster Join Date: May 2000 Location: Slovakia
Member: 1341 Status: Offline Thanks Meter: 0 | Hi man. I got problem with my 3210 ver. 6.00 My friend in service upgrade phone & change language to ver 6.00. But now I can't unlock it. When I tr to read the flash.out is blank and when want to write, then write Erase flash and Cmd error. I try all tia ,what I have ,but not success. If you can help me or send you working f_loader.bin, thank you. Mark |
02-07-2001, 19:07 | #5 (permalink) |
Freak Poster Join Date: Dec 2000 Location: Portugal
Member: 2785 Status: Offline Thanks Meter: 0 | hi. i' know this post is a little old, but i encountered the same problem. i have a 3210 v6 flash ID 00898890 that can't be read and, by mistake, i pressed F2. and flashed the phone. the area was correct (260000) but after erasing flash, i got this message: flash status error Now, my phone has a missing flash part and, of course, it won't power. anyone managed to solve this problem? can anyone send me or tell me which boot + f_laoder are correct? thanx |
02-07-2001, 23:19 | #6 (permalink) |
Freak Poster Join Date: Jan 2001 Location: Aveiro, Portugal
Member: 3066 Status: Offline Thanks Meter: 0 | Hi all, I had this problem too and i solved the problem by just replacing the 100ohm resistor by one of 390ohm. Doing this you can deliver more current to the vpp pin to enable reading/writing flash. The tia file that i used was the one that winflasher uses for Intel 3210 phones. Try this and tell me something. Bye, William |
02-08-2001, 01:33 | #7 (permalink) |
Freak Poster Join Date: Dec 1999 Location: Earth
Member: 751 Status: Offline Thanks Meter: 19 | Hi Skippy, Replacing 100 ohms resistor with 390 ohms will deliver less current...not more, since current is inversely proportional to the resistance. Maybe you mean replacing it with 39 ohms. Or paralleling 100 ohms with 390 ohms resistor.. Regards, neb |
02-08-2001, 03:55 | #8 (permalink) | |
Member: 3066 Status: Offline Thanks Meter: 0 | Hi neb, You are right what i ment was that if i replace the 100ohm resistance by one of 390 ohm the circuit will deliver less current to the vpp pin and deliver more current to the pin 14 of the IC. Because that was happenning to me with some 3210 v6 phones, so the first time it happened to me i used external power to the vpp pin and it worked fine, after that i replaced the 100ohm resistor and it works fine with all 3210 v6 that i tried to unlock. Sorry about the current stuff! Bye, William Quote:
02-08-2001, 04:38 | #9 (permalink) |
No Life Poster Join Date: Sep 2000 Location: UK York Age: 56
Member: 2008 Status: Offline Thanks Meter: 4 | Hi Everyone The original Dejan Diagram Says 100 Ohm Resistor, this should be 500 ohm resistor as our protege Zulea does in his diagram for cables for Nokey, this will limit current to VPP and avoid damage. Regards to All Charlie PS it been a long time Neb since I heard that line (Collage 15 years ago) |
02-08-2001, 11:11 | #10 (permalink) |
Member: 2785 Status: Offline Thanks Meter: 0 | sorry for the delay... i only had time to visit the forum now. but my problem was solved 5 minutes after the posting thanx for those who cared. since i'm using external power (5V) a 470 ohm resistor which was the one i was using, was way two low... so i upped it to 2k and now it works 100%... well 99% - still can't read those damn ATMEL flashes once again, thanx Dark Lemming |
02-08-2001, 14:22 | #11 (permalink) |
Freak Poster Join Date: Jan 2001 Location: UK
Member: 3153 Status: Offline Thanks Meter: 2 | Dark lemming, your external power supply, do u use batt or adapter ?.. and also do u use the 78l05 regulator .. and if u have any kind of diagram (or some written descriptions) is it possible to post, or e-mail then to me ..? would much appreciated .. respect.... Mick |
02-08-2001, 20:05 | #12 (permalink) |
Member: 2008 Status: Offline Thanks Meter: 4 | Hi Micklong Dont use power supply too much ripple use a 9V battery into a 7805 and output of 7805 to pin "14!!!" only 14 OK You can use a power supply but you will need extra circuitry to smooth AC. Regards Charlie [This message has been edited by Charly (edited 08 February 2001).] |
02-10-2001, 23:08 | #13 (permalink) |
No Life Poster Join Date: Nov 2000 Location: Boro Age: 37
Member: 2461 Status: Offline Thanks Meter: 22 | Hey Dark Lemming. Did u fix your 32 with partial flash when you changed resistor (& added external p.s.u) Cause I have exact same fault but I havent added 5v supply yet. Or did u use full flash ?? |
3210 v6.00 flash ID:20610F6A ... can`t be unlocked :( | din | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 11 | 12-04-2001 03:56 |
3210 v6.00 flashing stops 21800!!! Help me | dollyb | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 04-18-2001 18:10 |
Error loading full flash 3210 v6.00 | b.werrell | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 04-04-2001 20:24 |
please I nead full flash for 3210 V6.00 | gaz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 03-07-2001 12:51 |
Full flash backup 3210 v6.00 from D2 need | -Neb | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 01-10-2001 12:54 |
