02-06-2004, 19:56 | #1 (permalink) |
Freak Poster Join Date: Jan 2004
Member: 50304 Status: Offline Thanks Meter: 13 | 3310 auto power on I have 3310 with strange problem, it gets power on automatically when putting the battery and shuts off after sometime or by pressing the power button and it cannot be pwred on by pressing the pwr buttonm. the battery should be removed and put in back for it to get pwr on automatically. I tried by flashig and good working full flash and no result problem remains. Can any body help me to solve the problem Thanx a lot |
02-08-2004, 20:17 | #4 (permalink) |
No Life Poster Join Date: Sep 2003 Age: 66
Member: 39601 Status: Offline Thanks Meter: 13 | Actually I doubt that U checked the power sw track throughly , by the use of a mutimeter did U checked resistance aross power-Sw, and through C400 , and V414 ? Also did U checked the keypad Nos ( 3 , up , and down ) to ground ? Also did U checked R224 to Ground ? If complet those mesures , and cleans the board very well , there will be nothing elss than Ccont !! GoodLuck Br |
02-08-2004, 20:38 | #5 (permalink) |
Member: 50304 Status: Offline Thanks Meter: 13 | Dear Medz, Thanks Br. I will check all as u said and post the result can I download the old threads to study at offline. thanx once again Last edited by akfrm; 02-08-2004 at 20:49. |
02-08-2004, 21:24 | #6 (permalink) |
Freak Poster Join Date: Apr 2002
Member: 11352 Status: Offline Thanks Meter: 7 | I think like Medz said the power button is defective (must be changed) but in some cases if the phone is water damaged You should check R402,C400.Get a service manual and find them.Regards JOE. |
02-09-2004, 23:31 | #9 (permalink) |
Member: 39601 Status: Offline Thanks Meter: 13 | @akfrm.. Search the matter U'r looking for 1st , save the result page as an html file , them goto each thread , the important one , save it as text file to reduce the space and downloading time . GoodLuck M8 |
09-14-2004, 13:29 | #14 (permalink) |
Freak Poster Join Date: May 2004 Location: Iran - Qum Age: 43
Member: 66171 Status: Offline Thanks Meter: 6 | hi well, test this on a new phone : remove battery, press power key down and hold, insert battery, u see the phone will turn on, right ? do not release power key, hold it down, now press any key, u would see the phone will turn off and won]t power on again, u have to remove battery, now u can guess what happen to your cell phone. somewhere on mainboard or power switch itsef has been shorted. have fun |
09-15-2004, 20:23 | #15 (permalink) |
Member: 39601 Status: Offline Thanks Meter: 13 | Some times the presence of any residuals of cleaning ,dirty ,liquids , some times the flux it self . all of that formes a resistance across the power sw , that makes it not shorted and not normally acting. Just raise it , rassemble the phone , then put the battery. |
7210c auto power on & auto charging | ranem_111 | Nokia Hardware & Hardware Repair | 1 | 02-07-2010 12:31 |
very usefull solution for Nokia 3310 auto power ON/off | GSM SNIPER | Nokia Hardware & Hardware Repair | 4 | 07-03-2004 20:51 |
3310 auto power on | ataman | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 01-26-2004 01:30 |
3310 AUTO POWER ON when I put.. | sifasli | Nokia Hardware & Hardware Repair | 1 | 11-05-2001 02:08 |
3310 auto power off 100% solution | Fai555 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 07-07-2001 11:59 |
