03-25-2005, 17:15 | #1 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Capetown
Member: 91045 Status: Offline Thanks Meter: 8,696 | 3310 contact service after flash I got 3310 today which was on contact service so i flash it with newer version nothing happened then i read ppm from a working 3310 using UFS2 and write its ppm on the contact service 3310 it alive but when i put sim in it there is no signal and phone get restarted after 1 min again again i try to flash many times but same prob no signal and Phone restarted... |
04-03-2005, 12:27 | #6 (permalink) |
No Life Poster Join Date: Mar 2005 Location: MX-KEY is the BEST NOKIA TOOL Age: 43
Member: 123567 Status: Offline Thanks Meter: 44 | You must first have good look that phone have a good software 3310 or 3330 Next step is the perform full flash and repair imei. If phone have no problem with hardware you can solve problem with flashing. |
04-04-2005, 12:01 | #7 (permalink) |
Freak Poster Join Date: Oct 2004 Location: BG Age: 42
Member: 84922 Status: Offline Thanks Meter: 16 | Yes, check the right firmware - 3310/3315 or 3330. This phones shows contact service if they are with wrong software. Full flash with right software, update faid, rebuild IMEI (if needed) and Unlock him, this may repair the phone if there is no hardware problem. Good Luck. |
04-13-2005, 03:04 | #9 (permalink) |
Administrator Join Date: Jul 2002 Location: E G Y P T Age: 38
Member: 14178 Status: Offline Thanks Meter: 8,862 | make sure the ppm you read from the other phone match this phone mcu version better for you to flash full flash with mcu and ppm with the same version , write e2p in case , correct IMEI factory setting , update faid .... if not make a selftest for the phone with winddp , eeprome tools , prodigy , griffin ..etc and write down the resuilts |
how can i flash 7250i without get contact service after flash | makafy | Griffin | 3 | 06-08-2005 17:38 |
7210 In Contact Service After Flash | malta | Nokia Digital Core Technology 4 ( DCT-4 ) | 24 | 07-31-2004 18:32 |
8310 contact service after flash | GYZMO | Nokia Digital Core Technology 4 ( DCT-4 ) | 5 | 08-01-2003 17:49 |
3310 contact service after full flash dead.... | micmac | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 13 | 06-05-2002 08:14 |
