07-21-2002, 19:31 | #1 (permalink) |
Insane Poster Join Date: Mar 2002 Location: Computer Hospital Age: 47
Member: 9828 Status: Offline Thanks Meter: 2 | 3310: flash problem i try to load good ppm and mcu file for 3310 5.03 using rolis flasher the fone will accept the file but wont power on after flash. i try to read back its loaded file and the flasher would report failed mcu checksum,failed ppm check sum, failed eeprom security.i try to load again another good mcu and ppm files + virgin eeproms, but still wont power on, flasher still report failed mcu,ppm and eeprom data during read flash. i try to use different settings (delay index, battery ,cable)but still problem occur. this phone encounters contact service - dsp alive test failed on wintesla.i apllied hot air on ccont,cobba,hagar and 26mhz oscillator except for mad2 but no success- contact service still occur. what is the probable cause of dsp alive test failed. need a help on somebody about this prob. |
Flashing Problem UniversalBox 6110 Nokia Flashing Problem No available Boot Loader | Ravi Potdar | Universalbox | 1 | 05-29-2009 15:00 |
d780 flashing problem...after flashing ringer problem | gsm st | SWIFT Platform | 2 | 03-22-2009 22:29 |
N400 problem not power but charge is it flash problem ?? | crown | VLSI, Conexant, Skyworks and Old Models | 2 | 12-05-2003 17:23 |
3310: flash erasing error | ambot | Nokia Hardware & Hardware Repair | 3 | 12-11-2002 09:15 |
N3210 flash problem. flash id:FFFFFFF | pali | Nokia Hardware & Hardware Repair | 7 | 05-26-2002 22:48 |
