Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L )
Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) Nokia Legacy Models Like 1011, 1610, 211x, 2x20, 6050, 3110, 8110, NKxxx , 2100, 3210, 3310, 3330, 3410, 5110, 5210, 5510, 6110, 6150, 6210, 6250, 7110, 8210, 8250, 8850 also 9110 & 9210
Old 02-06-2002, 11:49   #1 (permalink)
Member: 8329
Question 3310 keeps on reseting... PLS HELP???
can somebody help me...
I got a 3310, IMEI is K as well as the Lock Area are K but keeps on reseting... Network Logo appears but no network bar then RESETS...
Tried to Upgrade and Downgrade but with no LUCK!
Anybody got a solution for This???
Thanks in Advance...
regards <img src="rolleyes.gif" border="0"> <img src="eek.gif" border="0"> <img src="rolleyes.gif" border="0"> <img src="eek.gif" border="0"> <img src="rolleyes.gif" border="0"> <img src="eek.gif" border="0">
Old 02-06-2002, 16:16   #2 (permalink)
Member: 8030
Post
What do you mean "imei is K and locks are K"? what does K mean?
have you done the FAID calc after you have upgraded/downgraded?
Did you make a full backup of your phone before u started playing around? If you did have you tried flashing it back? and if you flashed it back does it still keep resetting?
Old 02-06-2002, 16:45   #3 (permalink)
Member: 8329
Sorry... K is for short cut of O.K.
...yes I have calculated FAID, but still...and I <br /> <br />Didn't make any back up...
Any Solutions??? <img src="frown.gif" border="0">
Thanks for quick response... <img src="cool.gif" border="0">
<FONT COLOR="#ffff00" SIZE="1">[ 06 February 2002 17:47: Message edited by: Chryse ]</font>
Old 02-06-2002, 17:10   #4 (permalink)
Member: 8030
Post
Sounds like the eeprom is corrupted.
What info do you get if u read the phone with nokiatool 034 or 035 (or rolis or whatever) - are both imei's ok?
Only thing i can suggest is to read another 3310 (read full phone incl eeprom area) and then use Nfree V1.2 (or similar program) to change the imei to the same as the broken phone - flash the new file into the broken phone and re-calc FAID.
Not sure if it will work - but it's what i'd try if i was stuck in your position.
good luck,
Northernbloke
Old 02-06-2002, 17:18   #5 (permalink)
Member: 8329
I don't have NFree 1.2 only NFree 1.3... any diff?
Correct me if im right... ur saying that I will read a full backup of another phone which includes eeprom (w/ different IMEI) then use NFree 1.2 to change imei of broken phone - then flash it to broken Phone... I will give it a try and post in result asap...
thanks a looooooooooot... i really appreciate ur help... <img src="rolleyes.gif" border="0">
Old 02-06-2002, 17:33   #6 (permalink)
Member: 8030
Post
Nfree 1.3 doesn't have the change imei option anymore.
As I said - I "think" that reading a full flash including the eeprom from a known good phone then changing imei to the same as the phone u want to reflash it into "should" work. I've never actually tried it cos i've always had a good backup to fall back on and never screwed an eeprom area. But I have seen it suggested a couple of times on other forums.
If the phone is still under warranty you could always "break it" so it doesn't switch on (flash some crap starting from 0020000 would do it) then geta nokia service centre to fix it
Regards
Northernbloke
<FONT COLOR="#ffff00" SIZE="1">[ 06 February 2002 18:36: Message edited by: northernbloke ]</font>
Old 02-06-2002, 17:39   #7 (permalink)
Member: 8329
U got a point there...
... but I will push my luck to repairing the phone... Thanks again... I will try to find NFree 1.2... can you recommend sites who has this program???
Old 02-06-2002, 17:42   #8 (permalink)
Member: 8030
Post
Just been looking through the Nfree info and it looks like it's support for 3310 is a bit limited or proven not to work.
Guess you could try it - the phones not working now - i don't think u can make it worse. (make a full backup of it now so at least u can always return to the state its in now)
Failing that only other option i can see is the nokia trip
Good luck
Old 02-06-2002, 17:46   #9 (permalink)
Member: 8030
Post
Just e-mailed Nfree 1.2 to skyinet.net account
Regards
Old 02-07-2002, 02:04   #10 (permalink)
Alf
Alf's Avatar
Member: 6156
Post
How did you calc FAID? Box or log?
If it was by log I'd advise you to repeat it...
Did you log it when it was partially unlocked?
Old 02-07-2002, 08:19   #11 (permalink)
Member: 8329
@northernbloke
Hi... i've received your mail-thanks but there was no attachment NFree jst plain email... can u send me again... <img src="rolleyes.gif" border="0">
Thanks... regards <img src="smile.gif" border="0">
Old 02-07-2002, 08:21   #12 (permalink)
Member: 8329
@northernbloke
@Alf
I have calculated FAID using WinDLS 2.0 after flashing MCU+PPM... still keeps on reseting...
thanks for your help too Alf... Got any solution though... <img src="smile.gif" border="0">
Old 02-09-2002, 11:41   #13 (permalink)
Member: 8329
Good day people!
I ran out of solutions... yet my 3310 still keeps on reseting, I have already upgraded it to 5.03. IMEI is intact and O.K. as well as SP lock Data... everything is ok...
Old 02-09-2002, 11:43   #14 (permalink)
Member: 8329
Good day people!
MCC+MNC FFFFF CLOSED<br /> GID 1 0000 OPEN<br /> GID 2 0000 OPEN<br /> MSIN 0000000001 OPEN
Anybody has new solutions for these!
<br /> <img src="frown.gif" border="0"> <img src="frown.gif" border="0"> <img src="frown.gif" border="0">
Old 02-13-2002, 06:03   #15 (permalink)
Member: 7581
Wink
i think its a hardware problem...<br />chechk mail m8...
samsung x-660 keep on restarting pls help digitalcomgsm Trident/AGERE Platform 0 09-10-2008 10:08
My Treo 650 keeps on resetting ztreobot PalmOS /HP and others 3 01-21-2007 06:16
3310 Keeps On Re-setting 2lits Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 09-25-2004 08:09
griffin keeps on resetting dct3 fones! mp3hot Griffin 0 08-25-2004 23:17
C333 That keeps on resetting or something Bi0H4z4rD P2k Series 2 05-22-2004 04:12
Page generated in 0.37488 seconds with 11 queries
