03-02-2004, 02:21 | #1 (permalink) |
Junior Member Join Date: Feb 2004
Member: 56232 Status: Offline Thanks Meter: 0 | 3310 no power after liquid damage I have 3310 that was liquid damaged and no power,the phone has been cleaned up properly and ccont,pa,antenna switch replaced but still no power,hovever when the phone is connected to update sotware in rolis it makes a slight sound this is before the power on button is pressed and can not be flashed.Any suggestions will be very helpful. Thanks ash |
03-08-2004, 17:43 | #2 (permalink) | |
Freak Poster Join Date: Nov 2003
Member: 44625 Status: Offline Thanks Meter: 36 | Quote:
Trion | |
03-11-2004, 17:34 | #4 (permalink) | |
Trion | |
03-11-2004, 20:47 | #5 (permalink) |
Freak Poster Join Date: Apr 2003 Location: MUMBAI,INDIA Age: 63
Member: 27707 Status: Offline Thanks Meter: 6 | clean the entire pcb thoroughly ... may be 4 times ... and rehot it ...(to make sure that there is no water below the smd ).... if you have kept the phone .. without cleaning it .. oxide formation can give you a murmur sound from the speaker as you try to power on ... also with rolis 4.79 and a flasher cable you can flash the phone with good trusted flash file ..... see itz getting flashed ... if there is no error and flashing gets completed and still there is no display .. use epprom tool to find out the eprom functioning ... post the result please ... thanx .. and good luck Sunil |
NOkia n95 8GB no backlight after liquid damage | ryba10 | Nokia Hardware & Hardware Repair | 2 | 06-03-2009 03:03 |
nokia 6230 no ringer after liquid damage | FoneFixUk | Nokia Hardware & Hardware Repair | 4 | 03-16-2006 23:43 |
Nokia 3310 No Power After Flashing | iykemoses | Nokia Multimedia | 3 | 07-31-2005 14:26 |
6600 no power after whater damage - flash OK | et.com | Nokia Hardware & Hardware Repair | 3 | 06-29-2005 13:47 |
3310 no power after flash | conac | Nokia Hardware & Hardware Repair | 4 | 03-31-2005 20:44 |
