04-11-2002, 20:24 | #1 (permalink) |
Junior Member Join Date: Mar 2002
Member: 10504 Status: Offline Thanks Meter: 0 | 3310 no signal in some operator I have 3310 that dont have signal in 2 operators while the other 2 is fine (i try with 4 difrent kind of sim cards), when doing manual search, it only show up 2 operators (it should be 4). these 2 missing operators are gsm900, while the 1800 can work good. what I have done: Remove the Resistor --> same result Flash/upgrade soft --> same result Full flash --> same result Use eepron tools 3.1 --> same result Rehot Cooba, hagar, flash etc --> same result Change PA --> same result!!! please help.... |
04-14-2002, 15:06 | #2 (permalink) |
Freak Poster Join Date: Mar 2002 Location: Chester UK
Member: 10048 Status: Offline Thanks Meter: 3 | i also have a 3310 with the same problem but of the 2 networks i get one is vodafone gsm900 and the other is orange gsm1800 have tried allsorts but no change |
04-15-2002, 12:47 | #6 (permalink) |
Freak Poster Join Date: Nov 1999 Location: South East Asia
Member: 662 Status: Offline Thanks Meter: 0 | @Hanukkah What do you mean by ant switch? (antenna switch?) I don't think is the antenna problem cause the phone can operate normally with some operators (full signal and clear when use to make a call), while the other got no network. I already try to change the PA, result is the same. Can we check it using net monitor? Can it show up there if there is any error? BR W |
3310 No Signal | simonb | Nokia Hardware & Hardware Repair | 6 | 06-04-2006 20:13 |
j5 no network with some operators | Tbaba | Sony | 0 | 04-28-2004 18:15 |
nokia 3310 no signal in pakistan bought from china | GSM MIND | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 11-03-2003 22:56 |
nokia 3310 no signal in pakistan bought from china | GSM MIND | Nokia Hardware & Hardware Repair | 0 | 10-30-2003 10:10 |
3310 - lost signal after some Hours-(( | kostin | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-28-2002 07:22 |
