01-31-2005, 10:55 | #1 (permalink) |
Freak Poster Join Date: Jan 2005 Age: 41
Member: 103546 Status: Offline Thanks Meter: 7 | 3310 problem I try to programma 3310 The phone don't power on I start the programma flash I upgrade firm but when the progra con set UI give me error --------------------------- Error --------------------------- M-Bus Error: 1F 00 10 40 00 04 00 01 64 01 01 2E Bad Mob Ack --------------------------- OK --------------------------- Any help? |
01-31-2005, 14:39 | #2 (permalink) |
Freak Poster Join Date: Nov 2004 Age: 40
Member: 94090 Status: Offline Thanks Meter: 26 | I understand that the phone doesn't power on U tried to flash the phone(upgrade it) after ckeck cable,cable contacts on pcb 1-use latest version of the program that u use 2-setup the flashes of 3310 3-try to flash it 4-if error exists,u should follow hardware |
01-31-2005, 14:59 | #3 (permalink) | |
Member: 103546 Status: Offline Thanks Meter: 7 | I use UFS tornado 3 with hardware for soft I use last DCTX_UFSx 1.3_h all same problem flash program ok after flash gi me error thjs is the log of program Quote:
01-31-2005, 15:10 | #5 (permalink) |
No Life Poster Join Date: Sep 2004 Location: Romania Age: 42
Member: 81232 Status: Offline Thanks Meter: 196 | U must install the latest tia files and all vill be ok or the problem can be the cable connection , u can serch in ufs support for tia .. Br Ionel. |
07-18-2005, 18:38 | #9 (permalink) | |
Junior Member Join Date: May 2005 Location: Kosova - Pr&Mit Age: 41
Member: 148410 Status: Offline Thanks Meter: 0 | Quote:
M-Bus Error: 1F 00 10 40 00 04 00 01 64 01 01 2E Bad Mob Ack M-Bus Error: 1F 00 10 40 00 04 00 01 64 03 01 2C Bad Mob Ack and also this: 1st Boot Ok 2nd Boot Ok, DCT3, MAD: A1 G-01, ROM: 6, BUS: 16 FLID: 00898896,Int 28F320B3-T, I28f160.tia Software: V 06.07 17-06-03 NHM-5 (c) NMP. Algorithm Ok, [1986] Area: 0x00200000-0x003309FF Erased, Time: 00:12 MCU Flashing Completed, Time: 00:12 Area: 0x00340000-0x003CFFFF Erased, Time: 00:05 PPM Flashing Completed, Time: 00:05 Flashing Completed, Rebooting Mobile Power Up / Init Local Mode Failed ! Flash Id Failed esId regards... | |
3310 Problem... | [MoOkIe] | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 01-10-2002 15:03 |
3310 problems after instaling Blue leds!! | Me@n | Nokia Hardware & Hardware Repair | 7 | 12-18-2001 23:48 |
Nokia 3310 Problems - Turns Off By It Self | TheEckoMan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 08-14-2001 10:19 |
Nokia 3310 Problem | IrdetoMaster | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-08-2001 15:54 |
3310 problem wiht the leds | -FRILLE- | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 02-25-2001 12:52 |
