03-10-2004, 09:36 | #1 (permalink) |
No Life Poster Join Date: May 2001 Location: North Africa
Member: 4581 Status: Offline Thanks Meter: 1 | 3310 repair with twister flasher how to i just upgraded succefuly a twister flasher , so i wanted to test it with a noki 3310 contact service but it can't do it !! is mybe because when i start the soft by sarasoft i get a warning wich tells me that no wintesla folder have been found ? ANY HELP OR ADVICE ARE WELCOME |
03-10-2004, 10:40 | #2 (permalink) |
Junior Member Join Date: Oct 2001 Location: india
Member: 6991 Status: Offline Thanks Meter: 0 | hi wintelsa Hi make dir c:\wintelsa\nhm-5 convert files to wintelsa format seperate mcu and ppm and place them here .... search forum for converter dejan to wintelsa. |
03-10-2004, 12:53 | #6 (permalink) |
Freak Poster Join Date: May 1999
Member: 52 Status: Offline Thanks Meter: 13 | If I am not wrong, you need to download the flash from the support site and install the correct version of your flash file and flash your phone with correct MCU+PPM and reset all lock it should be ok. But remember, I try with 6110 and using incorrect flash, the phone will show incorrect version and if you erase the flash, the phone dead until you flash the correct flash to the phone provided the hardware is still in good condition Hope it can help some. |
03-10-2004, 16:44 | #7 (permalink) |
Member: 4581 Status: Offline Thanks Meter: 1 | Ian.or any others. I download from their support site my correct version but i see many files extractedon a folder, the problem is how to locate the MCU+PPM ?? this is my problem now ! thank you |
03-11-2004, 10:22 | #8 (permalink) |
Freak Poster Join Date: Mar 2003 Location: europe Age: 49
Member: 24373 Status: Offline Thanks Meter: 0 | @bonanza use better Nokia DCT3 flasher by Rolis to write fullflash and after Nokia Tool by Jordik v3.21 to change imei, update faid and unlock phone. WBR Marian |
*** gx12 flasher how to repair*** | FullFLASHgSMPH | Sharp | 6 | 05-02-2006 08:56 |
help wanted with twister flasher | orangeman2003 | Twisterflasher | 0 | 05-03-2005 01:22 |
T610 Dead Trying To Unlock With Twister Flasher | multiroamy | Sony Ericsson | 7 | 03-17-2005 19:43 |
Problem with Twister Flasher of second hand. I havén´t papers nor invoi | hyugater | Twisterflasher | 1 | 09-15-2004 18:27 |
3310 witch cobba ID 00000. how to repair?? | Gsmtronix | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 13 | 04-02-2002 10:21 |
