Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L )
Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) Nokia Legacy Models Like 1011, 1610, 211x, 2x20, 6050, 3110, 8110, NKxxx , 2100, 3210, 3310, 3330, 3410, 5110, 5210, 5510, 6110, 6150, 6210, 6250, 7110, 8210, 8250, 8850 also 9110 & 9210
Old 05-27-2004, 15:28   #1 (permalink)
Member: 63119
Thanks Meter: 2
Red face 3310 strange problem
hi
i have one 3310, the probs is like this after talking with someone till 20 min suddenly the mobile switched off and when i tried to switch it on, it was not getting on but when i had taken the batt off and inserted again the whole led's started glow and also started continues vibration butthere was no display, after then after sometimes the cel get dead and while pushing the switch on i got the beep sound from the buzzer, there is no shorting, i had changed the RINGER IC, POWER IC, DONE THE RE-BALLING OF HAGAR,FLASH,RAM, AND ALSO CHANGE THE PA AND 26MHZ CRYSTAL BUTTHE PROBLEM IS STILL THERE, I HAD TRIED TO FLASH BUT ITS NOT POSSIBLEthe voltage at switch is fine, butthe problem is still there please DO HELP ME I'AM VERYMUCH WORRIED
I WILL BE VERY MUCH THANKFUL OF URS GUYS
THANKX IN ADVANCE
Old 05-30-2004, 23:55   #2 (permalink)
das100's Avatar
Member: 40849
Thanks Meter: 285
change the LED control ic .tell me the result.
Old 06-01-2004, 05:45   #3 (permalink)
Member: 63119
Thanks Meter: 2
Unhappy
Dear I Had Allready Mentioned That I Had Also Changed The Ui Ic But There Is No Response, Please Do Help Me If Anyone Had Cleared This Fault.....................?
Old 06-03-2004, 16:35   #4 (permalink)
Member: 58466
Thanks Meter: 19
Put d cell in ultra sonic vibrator 4 a period of 30 mnts.b cos this problem happens mostly when d set is dropped in water,If u dont have vibrator pour enough amount of acetone,or ctc,brush hard with a tooth brush,dry 4 a while.&Let me know d result.
Old 06-03-2004, 18:09   #5 (permalink)
Member: 32182
Thanks Meter: 2
change coba !
n post the result!
Old 06-04-2004, 15:09   #6 (permalink)
Member: 63119
Thanks Meter: 2
Dear i had cleaned the board with ACITONE properly but there is no response
and i had also change the coaba but there is no response please do help me guys.........................
Old 06-05-2004, 08:21   #7 (permalink)
Member: 32284
Thanks Meter: 4
Hi!
Try with new flash chip..works for me..
When U say reball Do U have BGA plate to make bubles...
Good luck!
Big8
3310 strange problem sexygirl2 Nokia Hardware & Hardware Repair 2 09-21-2003 12:05
3310- Strange problem... iqballk Nokia Hardware & Hardware Repair 3 06-17-2003 21:32
3310 strange problem moonfighter Nokia Hardware & Hardware Repair 5 05-05-2003 04:11
Nokia 3310 strange problem misiniku Nokia Hardware & Hardware Repair 4 04-28-2003 01:21
3310 strange problem mahmoud Nokia Hardware & Hardware Repair 1 04-08-2003 00:07
Page generated in 0.17618 seconds with 9 queries
