3315 dead need help??? Hi, i have a 3315 dead set but it was contac service when i flash it for repair contac service then after flash i can't power on.I have used for flash original prodigy & rolis flasher.I try by sevarel files but still same position.So pls help me ASAP.thx in advance. proxy_gsm |
use knok for flashing but before that try to rehot ccont and/or cobba - in most cases that helps BR gladeo |
after changing ccont and cobba , sitll cannot work...~ i sugest u to replace the cpu ic~ |
change cpu Quote:
how do you change cpu?kindly post the steps |
I think U have to read old posts through the forum ( searsh for glued IC , epoxy ,and glued UEM etc ). |
Before u jump into changing the CPU, which is no easy task, I suggest U put back the ortiginal CCONT, COBBA by properly reballing them, check the battery voltage, ur cable and then flash a working flash file using nokiaflashtool. Good Luck! :) Trion |
