02-21-2002, 20:45 | #1 (permalink) |
Junior Member Join Date: Dec 1999 Location: norway
Member: 772 Status: Offline Thanks Meter: 0 | 3330 display problem |
02-22-2002, 04:57 | #2 (permalink) |
Freak Poster Join Date: Jan 2002 Location: Malaysia Age: 47
Member: 8898 Status: Offline Thanks Meter: 1 | Before you do anything, try to replace your LCD first. GOOD LUCK. <br /> <img src="biggrin.gif" border="0"> <img src="biggrin.gif" border="0"> <img src="biggrin.gif" border="0"> |
03-02-2002, 03:22 | #3 (permalink) |
No Life Poster Join Date: Jan 2002 Location: 24° 51′ 36″ N, 67°
Member: 8353 Status: Offline Sonork: 113276 Thanks Meter: 335 | change lcd hi try to change your lcd first...........if you dont want to change your lcd then stick something sticky i.e foamy tape or anything else that can press your lcd....it will solve your problem.. |
03-04-2002, 18:31 | #4 (permalink) |
Freak Poster Join Date: Aug 2001 Location: Pombal, Portugal
Member: 5977 Status: Offline Thanks Meter: 1 | before you replace your display, try to open your mobile and remove the display and clean the contacts in the mainboard. and back to replace the display, and you see that the problem is fixed. |
03-05-2002, 19:20 | #6 (permalink) |
Member: 5977 Status: Offline Thanks Meter: 1 | but your lcd doesnt work ? and you change your display for a new and good, and he donīt work in the same. can be problem of the mobile, or try to clean the contacts of display in the mainboard of the phone. |
03-05-2002, 19:25 | #7 (permalink) |
Insane Poster Join Date: Nov 2001 Location: RP
Member: 7581 Status: Offline Thanks Meter: 0 | blur lcd ======================================== I have one with LCD BLUR all the way, I've tried to changed the LCD but still the same PROB..... Just BLUR Please help ======================================== try to contras ur lcd using nkprofile.... |
03-06-2002, 09:29 | #9 (permalink) |
No Life Poster Join Date: Dec 2001 Location: In front of my computer
Member: 7741 Status: Offline Thanks Meter: 111 | all tested coontrast adjustment, change couples of lcd, UI reset, UPGRADE the versions up and down, but still no joy, i guess it's hard ware problems, i try to rehot the 3rd part of 3310 phone flash ic, external flash ic, MAD2, charging ic, CCONT, COBBA, and now the contrast is back to normal, but the worst thing coming out is that, i can't use the nkprofile to set the contrast, it show cable not connected...... |
5800 Display Problem (With Display On FBUS Cable But No Display using Regular Battery | eyestrain | Nokia Base Band 5 ( BB-5 ) | 1 | 06-21-2009 20:11 |
v3 display problem.Some few seconds display getting off | sharaz191 | Motorola Hardware Repair | 0 | 10-31-2007 12:45 |
6681 Display Problem-but In It 6680 Display Works Fine | zonetrichur | Nokia Hardware & Hardware Repair | 0 | 03-11-2007 14:04 |
3100 lcd - no display and then got display problem. | hooi76 | Nokia Hardware & Hardware Repair | 5 | 03-15-2006 17:41 |
NOKIA 3330 Display Strange Problem!!!! | samalex | Nokia Hardware & Hardware Repair | 6 | 01-17-2003 15:02 |
