Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L )
Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) Nokia Legacy Models Like 1011, 1610, 211x, 2x20, 6050, 3110, 8110, NKxxx , 2100, 3210, 3310, 3330, 3410, 5110, 5210, 5510, 6110, 6150, 6210, 6250, 7110, 8210, 8250, 8850 also 9110 & 9210
Old 06-15-2002, 21:04   #1 (permalink)
Member: 10085
3330 not ringing
have a 3330 which wont ring but i have a 3310 which does. I know this is a very popular fault with the 33xx which is normaly casused by liquid damaged but is there a solution to this without soldering anything? i can take parts from a the 3310.
thanks
Old 06-21-2002, 03:37   #2 (permalink)
Member: 12869
Thanks Meter: 3
take out the PCB....look for the "N400" (near to buzzer contact points, with 10 legs on each side.) then u look again on the "N400" Right hand side...from the top u count....until the FIFTH leg.....then use a hairline wire to join the FIFTH leg...to the buzzer contacts(on the PCB,not to the BUZZER!!!) on the NEGATIVE point. Try it...it works 100%........cheers! It works for 3310 so it should work for a 3330.
Old 06-21-2002, 03:45   #3 (permalink)
Member: 10085
sorry to sound stupid but what is a hair line wire? and wont it fall out of place when the phone vibrates? cheers
cyber killer
Old 06-21-2002, 05:11   #4 (permalink)
Member: 12869
Thanks Meter: 3
A hair line wire is a piece a wire put out of a whole bunch of them, take for example you have a wire and you cut it, then you have shiny copper wire threads sticking out, if you put one of them, you will have a hair line wire and no, it won't fall out if you solder it properly, believe me it works, I've tried it alot of times. There is a broken link that is the reason for the buzzer not working, good luck but i don't think you'll need it if you follow my instructions
t610 not ringing and not vibrating mikimaus Sony Ericsson Hardware Repair 2 08-16-2007 03:26
Nokia 3330 slow ringing tones taiyeadekeye Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 08-01-2003 00:12
3330 doesn't ring after "contact service" problem. mourad_t Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 05-26-2003 17:39
3330 no ring tones bangerman Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 06-16-2002 15:26
j5 not ring , not vibrate tkerek Sony 1 06-07-2002 22:15
Page generated in 0.14631 seconds with 9 queries
