01-12-2004, 03:17 | #1 (permalink) |
No Life Poster Join Date: Mar 2002 Location: Europe, Lemberstadt Age: 53
Member: 9889 Status: Offline Thanks Meter: 50 | 3330 and PPMMaker - need some help but when i write PPM or full flash saved from PPMMaker - all changes ok but phone loses network (i tried to open PPM separately and full working flashes) I did repairing procedure (reset, FAID update,...) with many 3310 and 3330 phones but in my case it doesnt works I think a have bad checksums - i tried recalculate it with PPMManager, Chkfix, G3nOlite but without success? Any good advice??? Who did it before? Thanx br |
01-12-2004, 23:09 | #3 (permalink) |
Member: 9889 Status: Offline Thanks Meter: 50 | This phone makes me crazy really i tried thousand combinations When checksums are ok then i got CS or no signal&phone restarts But one time when i worked with full (mcu+ppm+eeprom) flash - i got working phone (with signal and modifications) but in this case MCU checksum is DEAD - does it correct when phone works with bad MCU checksum? For me is most simple and safe to modify only PPM - but in this case when i upload modif. ppm i got ContactServise i told - i repaired more phones with CS or restarting because i did tested and worked procedure, but after flash modifications i never cant get phone works Does exist really simply and working solution? Who did this? |
01-13-2004, 02:00 | #4 (permalink) |
No Life Poster Join Date: Apr 2002 Location: Flash Age: 44
Member: 11208 Status: Offline Thanks Meter: 11 | Do u know u should use mcu+ppm=200000-550000 such a flash u should use? Not one by one,mcu also ppm. Fisrt repair checksums then kill both of check then ok. |
01-13-2004, 21:02 | #5 (permalink) |
Member: 9889 Status: Offline Thanks Meter: 50 | i did next: 1)read flash from working phone 2,097 Mb(its full flash including eeprom 2) open by PPMMaker and made changes, save flash (update CS checked) 3)open by G3nOlite v1.7b, Fix all checks, kill MCU, kill Faid, save flash 4) writing flash - phone works good and mods are present, BUT phone has DEAD MCU!!!(checked by Rolis) does it correct? tried other combinations - no success maybe i must edit flash without eeprom? but i cant get correct flash i tried get flash (MCU+PPM) thru KNOK 95 (option conwert Wintesla to fls, and select add PPM), but in this case flash has about 1,8Mb and G3nOlite try to open flash it corrupts(prog closes) tried with 3310 v 6.07 - the same result what am i do wrong? |
Need Some Help With BOLD and Maps | GegoTheWizard | BlackBerry (RIM) | 2 | 05-30-2011 23:57 |
need some help with nokia 6280 and phoenix | skoota121 | Nokia Base Band 5 ( BB-5 ) | 2 | 12-20-2006 05:19 |
I need some help about motorola v3c[Help] | pentagono | Motorola CDMA | 3 | 07-12-2006 16:09 |
3310 and PPMmAker - need help | SVH | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-26-2004 02:13 |
