02-24-2004, 00:25 | #39 (permalink) |
Freak Poster Join Date: Sep 2001 Location: Galaxy far far away!
Member: 6428 Status: Offline Thanks Meter: 43 | @All Ok. Heres the clear pics that for converting 3390 to 3310. Just use acrobat reader to open the file. This solution works 100% in GSM 1800 50/50% in GSM 900, Co'z some work fine and some not. Just follow the instructions carefully to avoid some problems. Thanks to D_bug and others who contribute this pics and ideas. Good luck m8's. Here's the link:http://groups.yahoo.com/group/xtreme...les/GSM/NOKIA/ Just click on Join the group so that you can download the file. Best regards, Dj King |
02-24-2004, 01:04 | #40 (permalink) |
Member: 6428 Status: Offline Thanks Meter: 43 | Originally posted by bbbbbb: I converted 3390 into 3310 and now Nokia finds network(we have 900/1800 Mhz) but the problem is that if I do not press any key or make a call within cca 13 second LCD become gray( there is nothing seen on a display ) and mobile is unreachable. But if I press any key, the display is light again and I can use the phone again.I checked with NET MONITOR and found out (on the first screen) that carrier number is 0. Any idea how to solve that problems. Thanks for help ++++++++++++++++++++++++++++++++++++++++++ Did you change the MAD2? If yes, there's a solution for that problem. Some 3390 board that has MAD2 "4370677" w/c will be replaced by V16"4370678", have some modifications in the circuit board. OK heres the solution: All you need is a VOmeter and a bypass wire"Magnet wire AWG#34 at least". and solder station and soldering lead. Try power on the fone without LCD frame. Now the fone's lcds glow. Right? Now, set the VOMeter to 2.5v, DC. Put the black test probe to ground and the positive probe to the LCD terminal no. 1 or 2 I think. Now the VOMeter pointer reads a voltage, right? Approx:1.8 to 2.4v dc. Now, observe the reading until the led's lights turns off. Now, as the Led's light turns off, the voltage across the lcd and other parts of the fone also drops resulting a blank screen and a dropping signal. Now thats the solution for that problem. Now, all you have to do is to get a bypass wire and put it across the Lcdv+ and the v+ on the led side. And the problem is sorted. I encountered this problem so many times already everytime I change the MAD2 to V16. Good Luck and hope this helps! Dj King Last edited by Dj King; 02-24-2004 at 23:56. |
10-27-2006, 04:25 | #45 (permalink) |
Crazy Poster Join Date: Apr 2006
Member: 260419 Status: Offline Thanks Meter: 1 | Here's the step by step procedure: 1. Modify all the parts or hardware stated in the pictures. 2. Now, after modifying the hardware, flash the fone with a 2mb 3310 full flash. Unlock, change IMEI, update faid and thats it. Note: Not all 3390's can be easilly be converted to 3310. Because some 3390's has a ROM5 CPU's only "4370677". You have to change the ROM5 CPU's to ROM6"4370687". |
3390 to 3310 | Moosani | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 46 | 11-26-2004 13:59 |
@ mod. ed2k_3 and Dj king about 3390 to 3310 | baraka42 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 04-17-2004 04:56 |
3390 to 3310 | jigger1001 | Nokia Hardware & Hardware Repair | 3 | 11-08-2003 23:32 |
how to convert 3390 to 3310? | Toucher | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-18-2003 11:46 |
