07-04-2003, 14:45 | #5 (permalink) |
Junior Member Join Date: Mar 2003 Location: Cairo, Egypt Age: 41
Member: 25701 Status: Offline Thanks Meter: 0 | you will have no chance to update FAID for 5210 so easy..use g3n0lite and open your flash file with it and select kill flash check/FAID the save the file..write it to your phone..use rolis 1.9 to update the faid..reset factory settings...the you'll get network |
07-04-2003, 19:23 | #7 (permalink) | |
No Life Poster Join Date: Feb 2003 Location: ..::India::.. Age: 40
Member: 22538 Status: Offline Sonork: 100.67180 Thanks Meter: 2,252 | Quote:
killing it for only 1 flash is not usefull,, it is only usefull when doing some r&d in editing a flash file.... what does it do with 5210 flash??? Naman | |
02-06-2004, 15:57 | #8 (permalink) |
Junior Member Join Date: Jan 2004 Age: 43
Member: 50515 Status: Offline Thanks Meter: 2 | 5210 No Network after flash - SOLUTION 100% Many times i got no network after flashing a 5210(same problem with 3410, when downgrading) , especialy after flashing with different version. FAID, eeprom rewriting, SFR, imei & oth were no help. Solution tested in more that 10 phones , working from the 1st try. Read original flash with knok_ 2k3 (0x2.. - 0x6... so includind the eep) ... save the file ... open the file (fullflash saved earlier or a fullflash wich doesent have language desired, but for wich u have the ppm same version with desired language) with rolis 4.79 ... split mcu and ppm, load new ppm with desired language (keep the version) update ppm to fullflash ... save the full flash open the new flash with knok 2k3 .. write to u phone and then FAID with rolis 1.8. That's all ... |
k790i no network after flash wrong flash to k800 | ahmad5175 | Sony Ericsson Hardware Repair | 4 | 06-08-2009 09:11 |
n95 8gb rm-17 no lcd after flash whit wrong file | gabriel148 | Infinity-Box | 6 | 11-05-2008 23:38 |
No network after flashing U8500 with unlocked flash - What's wrong? | James_S | FuriousGold | 9 | 05-10-2008 13:56 |
9210 no network after flashin' with GRIFFIN | zmicier | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 12-19-2005 14:05 |
3350/3410 and 5210 NO NETWORK AFTER CONTACT SERVICE REMOVED | regmwesiga | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-04-2004 16:08 |
