10-02-2002, 13:27 | #1 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Serbia
Member: 9165 Status: Offline Thanks Meter: 0 | 5210 problem. Help! When i try to DL flash (with Dejan usual flasher) from Knok (build 1), Knok says Cannot prepare phone? And when i start WINDLS 4.1 (with Dejan BOX) after Get Info (that work OK), select Upgrade, and select PPM, after that when i turn ON phone to start flashing, WINDLS says "Cannot prepare flash" ???? What that's mean? Some new flash or something else? Help! |
10-03-2002, 16:36 | #4 (permalink) | |
Member: 9165 Status: Offline Thanks Meter: 0 | Quote:
I read in Forum about litlle change in ALIAS.ID, and than phone can be readed with small Dejan, and of course writen with it. But, what to change in Alias.ID, and where to find boot loaders for that C4 flash type in 5210? Anybody have complete solution, step by step? In the Forum i found message about it, but, nowhere is explained with details Can the Moderators do that? | |
10-03-2002, 16:48 | #5 (permalink) |
Freak Poster Join Date: Apr 2002 Location: Yugoslavia Age: 47
Member: 10594 Status: Offline Thanks Meter: 83 | Hi! You have to use the newest flash and boot loaders for flashing 5210. Knok is good program for it. And try to move up or down that 2 screws on the connector, I had the same problem and I sllved it by taking out that 2 screws. It seems that there is a little difference between phones. Regards from Becej |
10-03-2002, 16:56 | #6 (permalink) | |
holes in phone near phone pinouts. When i connect to the phone with Dejan full box, phone is readed by MBUS, but when i want to flash or read flash i receive "cannot prepare phone" (same on WINDLS 4.1, and Knok 22). I want to try with small Dejan to read flash, but i dont know what to put in Alias.ID for NSM-5, and which loader to use, i use 956, but, i receive from flasher (boot cont). | |
10-03-2002, 17:01 | #7 (permalink) |
Member: 10594 Status: Offline Thanks Meter: 83 | I am using small Dejan's interface with Knok, it works OK, and you only have to pick the phone model, the program will do the rest. You must have 4 pins on the connector, and try moving them up or down with the screw beside pins. I thing you only have a bad contact problem |
10-03-2002, 17:06 | #8 (permalink) | |
ih 2 plasticna fiksirajuca dela) and tha to try? When i put battery i cant move up or down, is so tight (no space for moving). | |
10-07-2002, 15:50 | #11 (permalink) | |
all programs working very vell But, i still dont know why usual LPT setting will not take effect. | |
acount id problem.help uregent plz [SOLVED] | dani2080 | PolarBox 3 | 2 | 03-29-2010 12:46 |
5210 flash problem HELP | kreten | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-07-2004 21:13 |
strange 3330 & 5210 problem | sawa | Nokia Hardware & Hardware Repair | 3 | 12-04-2002 01:19 |
5210 problem! | DABOSS | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-02-2002 18:14 |
5210 problem??? take a look here!!!!! | vule | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 05-16-2002 18:05 |
