08-08-2002, 08:21 | #1 (permalink) |
Freak Poster Join Date: May 2002 Location: Perth, Western Australia Age: 45
Member: 11937 Status: Offline Thanks Meter: 1 | 6210 Energy Management Calibaration Has anyone actually done energy management calibration using the cracked Wintesla? Ive got a 6210 which displays low battery about 5 minutes after been charged. The battery is new. I want to do Energy management Calibration, but iam not sure how to go about doing it. Every time I run it using the cracked DLL's i get a message "wrong battery type". Thanks Scaramouche |
08-08-2002, 10:11 | #2 (permalink) |
Registered User Join Date: Jun 2001 Location: x
Member: 4989 Status: Offline Thanks Meter: 13 | No way without special hardware ! You might try something else: flash another EEPROM then try again, if problem remains take a look in 6210 service manual for fault ! (Maybe PA faulty) |
08-09-2002, 02:00 | #3 (permalink) |
Member: 11937 Status: Offline Thanks Meter: 1 | What special hardware would you need? Not a PKD-1 dongle thats just to run the program, not a FLS-8 thats for flashing. Iam wondering if anyone has actually calibrated a phone with wintesla. |
08-10-2002, 10:55 | #4 (permalink) |
No Life Poster Join Date: Apr 2002 Location: Radiometer Medical ApSBrønshøj Age: 51
Member: 10854 Status: Offline Sonork: 1578988 Thanks Meter: 3 | Hiya I did power management a lots of times without any special equipment...Just cracked wintesla ( no pkd1 ) and serial cable... If u r sure that battery and phone hardware are ok then just write default factory values for battery and charger...In most cases this will work...When wintesla asks to set voltage to 10V just click ok and do what i said above When i calibrate charging only i use fast travel charger instead of normal one ( 32 Hz pulses ).... And u can do same with tx part...factory values are ok for most nokia phones.. BR Vue |
08-11-2002, 02:49 | #5 (permalink) |
Member: 11937 Status: Offline Thanks Meter: 1 | Ok, correct me if iam wrong... 1) Phone is powered from benchtop power supply - Ive built a service battery using schematics i found on the forum, its the one with the 330ohm resistor between + and the btemp. 2) Connect charger 3) Start wintesla 4) Run calibartion setting power supply to whatever it asks. Am i right? Thanks |
08-12-2002, 08:53 | #6 (permalink) |
Member: 10854 Status: Offline Sonork: 1578988 Thanks Meter: 3 | Hiya I don't have service battery...Instead of that i use standard NiMh battery and fast travel charger...... Factory defaults will be set to charge and battery even without that. And in most cases it will work 100%.... BR Vule |
08-14-2002, 23:40 | #7 (permalink) | |
Freak Poster Join Date: Dec 2001 Location: Banana Republic of Germany Age: 55
Member: 7769 Status: Offline Thanks Meter: 0 | Quote:
i´vs done it many times with original nokia hardware, do what wintesla wnt and everything will be fine | |
Energy management and RF calibration using Cruiser, possible? | virtue | Cruiser Suite | 4 | 11-03-2008 13:59 |
Energy Management Calibration Software for WD2 phones | ALEX BRAIMOH | WD2 & APE (Symbian Phones) | 2 | 08-10-2007 12:43 |
run energy management calibration yes, but how? | emso | Nokia Hardware & Hardware Repair | 1 | 02-04-2004 07:26 |
nokia 'how to calibarate the energy Management" | joe locks | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 05-13-2002 11:03 |
