02-02-2002, 09:59 | #1 (permalink) |
Junior Member Join Date: Feb 2002 Location: saaneyt
Member: 9140 Status: Offline Thanks Meter: 0 | help on rolis flasher (nokie 3210 nse8) |
02-02-2002, 10:20 | #2 (permalink) |
Junior Member Join Date: Dec 2001 Location: uk
Member: 7895 Status: Offline Thanks Meter: 0 | what have u got your LPT port set to it should be on ecp or epp.<br /> check u have done this first<br />then check it if this doesnt work try using Nokia flash tool by cyberdog<br />if u need this mail me <br />regards<br />budget |
02-02-2002, 10:24 | #3 (permalink) |
Member: 9140 Status: Offline Thanks Meter: 0 | how can I set it ? can you help me? Im newbie.. And if you send me that program it will be good for me.. email: [email protected] |
02-02-2002, 17:51 | #5 (permalink) |
No Life Poster Join Date: Jul 2001 Location: Viet Nam Age: 49
Member: 5487 Status: Offline Thanks Meter: 5 | Hi<br />Rolis can unlock your fone with no problem. If you use cable have BTEMP pin so it automatic power up and unlock . don't need to press power button. but not have BTEMP pin you must press PWR button. if it only say TX = hight i think you must clean connector... <br />best regards |
02-02-2002, 18:43 | #7 (permalink) |
Junior Member Join Date: Dec 2001 Location: Just right here.
Member: 8143 Status: Offline Thanks Meter: 0 | If you have problem with Rolis software try the elimination method: 1. check if connectors are all ok especially the contacts.<br />2. change the delay index several times to suit your computer's need. (1,2,3,4,5)<br />3. check if you have sufficient battery power.<br />4. reset your computer and start all over again.<br /> <img src="smile.gif" border="0"> that's all folks |
02-02-2002, 19:49 | #8 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Croatia Age: 45
Member: 4185 Status: Offline Thanks Meter: 3 | you wrote: "When I try to turn off the phone its saying:<br />preloader init error:<br />your phone ram is bad<br />or control cable" Or your writing is bad or you've done a mistake... The phone must be OFF when you do something with flaher cable......<br />and then power ON when it asks....<br />Only if your writing is good...<br />If you wrote that by mistake then check the pin VPP in your cable......<br />and something else......<br />look the flash id....and check the flash id with dark flasher shell ID TABLE....... |
Rolis Flasher problem Help! | kennyt1 | Nokia Multimedia | 0 | 11-11-2006 07:05 |
Rolis Flasher don't work on one partition, but works on the other... | GeeZuZz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 07-26-2002 00:43 |
Help on 8xxx MBUS for Rolis Noktool 1.15 | philkho | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 03-09-2002 23:03 |
Help can someone show me where i can down manuel on rolis 477 | online 2000 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-21-2002 01:00 |
Rolis flasher and VsH-GsM MBUS flasher... Are these WORKING for anyone? | crusher | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 01-19-2002 22:15 |
