07-22-2002, 03:15 | #4 (permalink) |
No Life Poster Join Date: Dec 2000 Location: Slovakia, Brezno
Member: 2721 Status: Offline Thanks Meter: 23 | check the small 5 pins componnets near connector for shortcircuit. These are 4 diodes in one package, is it a kind of protection. Refer to service manual for more info. |
07-24-2002, 18:40 | #6 (permalink) |
No Life Poster Join Date: Apr 2002 Location: Radiometer Medical ApSBrønshøj Age: 51
Member: 10854 Status: Offline Sonork: 1578988 Thanks Meter: 3 | Hiya It's hardware prob. Do what ARS said . Also check lines from connector to mainboard, clean connector from outer side Flashing works b'cause flashing in dct 3 phones is possible to do in 2 ways: FBUS or FLALI connector which is cut off from board after initial factory flashing... Did u test cable with other phone ???!!! LOL Now serious....It could happened that Mbus line is broken so trace it using service manual... BR Vule P.S. If u use normal mbus cable with DEJAN repair tools it won't work...Use dejan shematic with 74HC14 |
07-25-2002, 10:33 | #7 (permalink) |
Freak Poster Join Date: Feb 2002 Location: Jakarta
Member: 9261 Status: Offline Thanks Meter: 0 | modified your cable your cable using FBUS system. try to modify it: 1. open your connector and you see that 3 cable with color black , blue & white 2. blue in pin 7, whit in pin 8 & black in pin 9 3. desolder blue & white cable in pin 7 & pin 8 4. join blue & white cable, soldering it in pin 6 (MBUS) 5. you now have MBUS cable........ |
SAMSUNG S501i dont work and dont boot | gagafree | Samsung Hardware Repair | 0 | 12-15-2008 17:13 |
6210 mbus problem | kevin03 | Nokia Hardware & Hardware Repair | 3 | 12-04-2006 18:34 |
6210 mbus prob. | s4sajii | Nokia Hardware & Hardware Repair | 1 | 12-28-2002 19:18 |
6210 Dead? Dont know ther version? Read on... | X-Shadow | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-27-2001 21:41 |
HOV CAN I OPEN NOKIA PHONE IF THE COMUNICATION WITH MBUS DOESN'T WORK | Marsovec | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 03-26-2000 20:23 |
