08-19-2002, 15:04 | #1 (permalink) |
No Life Poster Join Date: Feb 2002 Location: burning phones
Member: 9700 Status: Offline Thanks Meter: 62 | 6210 problem thanks !!!!!!!!! |
08-20-2002, 19:53 | #2 (permalink) |
Crazy Poster Join Date: Jul 2002 Location: Estonia Age: 39
Member: 13566 Status: Offline Thanks Meter: 0 | possibly some flash checksums are wrong. download the flash from phone and calculate checksums with ppmsplitfix v2.7. if this will not work flash new working mcu+ppm to phone and do factory reset. i'll hope you'll get it working. |
08-23-2002, 01:01 | #5 (permalink) |
Member: 9700 Status: Offline Thanks Meter: 62 | oh, oh... I can't read flash, I have tryed Rolis DCT3 flasher478 and Noki7.3 but I can't read flash, it stops when start to read. I have re-flashed and flashed a virgin eeprom but this is no solution. eeprom tools say one problem but If I disconnect and reconnect, eeprom tools say other problem, and other... it seems to work badly... and now eeprom tools says only "phone not conected!" If I use Nokia Tool by Rollis it say that the IMEI is "??????????4", but if I try to change IMEI it say "error changing IMEI" I think there's no solution any idea? thanks DJ_Andy, thanks Norton sorry for my bad english best regards |
08-23-2002, 08:42 | #6 (permalink) |
Freak Poster Join Date: Apr 2002 Location: Romania Age: 41
Member: 11445 Status: Offline Thanks Meter: 0 | The battery is fully charged???? If so, try to use Knok build 21. In some cases Rolis is not working corectly. Your phone was droped or rain problem? Try to clean connectors. Search for full flash (mcu+ppm). Good Luck! |
08-24-2002, 10:07 | #7 (permalink) |
Member: 9700 Status: Offline Thanks Meter: 62 | ups! there was connector problem I have solved it and now I have repaired contact service but now the phone turns off, It requires security code but when I will type it the phone turns off... you know the problem? thanks a lot!!! first problem solved!! go to the second hehehehe |
08-31-2002, 22:55 | #10 (permalink) |
Member: 13566 Status: Offline Thanks Meter: 0 | i think the flash is bad. you shold try to owerwrite the whole flash. it's because sometimes some addersses aren't flashed correctly. i had this problem with my computer bios. or you have tried it already? have you dropped the phone on ground or something? if it worked before and you haven't made any damage for it now then it must be software problem. the file what you are flashing - is this ok? try to download other full flash (be sure it is with eeprom)... and reflash... and faid etc. good luck. |
3330, 6210 problems after upgrade | reo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 02-27-2002 21:34 |
Major 6210 problem | outerc0re | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 02-18-2002 10:45 |
6210 PROBLEMS | BUZZ | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-11-2001 23:31 |
6210 PROBLEM | BUZZ | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-04-2001 02:27 |
3310 and 6210 problem here . | makona | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 05-23-2001 10:44 |
