Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L )
Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) Nokia Legacy Models Like 1011, 1610, 211x, 2x20, 6050, 3110, 8110, NKxxx , 2100, 3210, 3310, 3330, 3410, 5110, 5210, 5510, 6110, 6150, 6210, 6250, 7110, 8210, 8250, 8850 also 9110 & 9210
Old 06-01-2001, 12:17   #1 (permalink)
Member: 4398
Post 8210 contrast problem is there a program that will fix it
the phone powers on as the leds power up but nothing appears on screen.
does anyone ahve a program to fix this
its and 8210 v5.25
Old 06-02-2001, 14:34   #2 (permalink)
MDR
Member: 1272
Post
if its just contrast [are you sure], then use NKprofile....
but, i think, its a hardware problem. check LCD or have elastomer changed
Old 06-02-2001, 15:35   #3 (permalink)
Member: 4398
Post
the screen was working fine until i reflashed it. how can i check to see if its working?
Old 06-02-2001, 15:39   #4 (permalink)
Member: 4398
Post
i put the charger in and the bars came on as usual as though it was charging so i dont think its a contrast problem anymore.
Also loads of random black lines came on and when i pressed the screen it went blank.
do you think this is an lcd problem.
Old 06-02-2001, 16:19   #5 (permalink)
Member: 3395
Post
Sounds like a new screen required to me
Old 06-03-2001, 13:25   #6 (permalink)
Member: 3900
Try it with wintesla interface test... it may help.
Old 06-03-2001, 15:25   #7 (permalink)
Member: 2628
Post
Try to change the display !!
Good luck!
Old 06-04-2001, 16:34   #8 (permalink)
rothmanns's Avatar
Member: 1544
Post
i think its elastomer problem... try to change it...
Old 06-04-2001, 17:33   #9 (permalink)
Member: 4398
Post
its definitely a screen problem.
how do i change the elastomer?
Old 06-05-2001, 03:16   #10 (permalink)
Member: 4771
Post
greetings!
i had the same problem with a 6210 before like after flashing there is no display and when during power on you will see random display of bars. why not try restoring the 8210 backup flash --assuming you have one.
see if it works.
ian
Old 06-05-2001, 17:37   #11 (permalink)
rothmanns's Avatar
Member: 1544
Post
remove six screws and separate the pcb with the lcd frame... remove the elastomer carefully the green thing connecting the lcd with the pcb... u can use elastomer of 3210 lcds just cut it into half with a clean blade... adjust the speaker connector.... try to put the backup flash first coz i think its more easier to do....
any problem i will fix it sazr Off Topic Zone 0 03-24-2010 18:20
!! servers is down ¿when will fix it?? ktienda Universalbox 0 12-14-2007 19:43
Need program that will Unlock V975 joolsman P2k Series 8 05-16-2005 16:26
is there any program that can format locked mmc?? Platijet Universal GSM Software 3 05-16-2005 13:05
Is there a program that could read PUK codes of SIM? philkho Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 03-17-2001 17:52
Page generated in 0.41882 seconds with 11 queries
