Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L )
Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) Nokia Legacy Models Like 1011, 1610, 211x, 2x20, 6050, 3110, 8110, NKxxx , 2100, 3210, 3310, 3330, 3410, 5110, 5210, 5510, 6110, 6150, 6210, 6250, 7110, 8210, 8250, 8850 also 9110 & 9210
Old 07-27-2002, 04:23   #1 (permalink)
Member: 14106
8210 Flashing Nightmare
Hi all,
My M8 has asked me if I can fix his 8210 that won’t switch on, he was given the phone in this state.
This 8210 won’t switch on so I thought I would flash it by using rolis 477 with a full back up I made from my 8210.
The phone starts to flash ok but then a message pops up that says:
“Flash Erasing Error
Must Receive 91 00 FF But Received FF FF FF
Check Vpp, Vbatt Voltage, Phone Type”
I have tried different flasher programs & tried flashing the MCU & PPM & virgin eeprom but no joy.
Can anyone explain how to sort this, or is the phone a paperweight?
Cheers, UB.
Old 07-29-2002, 00:38   #2 (permalink)
Member: 14106
Come on guys,
someone out there must have came across this problem before.
Tell me how to sort it....PLEASE
Old 07-30-2002, 14:30   #3 (permalink)
BufferMess's Avatar
Member: 9856
Did you try fully charged battery?
Old 07-30-2002, 22:18   #4 (permalink)
Member: 14106
Hi thanks for you reply,
Yeah I have tried with a fully charged battery & with the charger plugged in as well…& many other combinations…...lol.
The problem message seems to pop up in approx. the same place (00261000) on each flashing attempt.
As this is the MCU area I read the MCU from my working phone a small block at a time,
00200000 – 00210000,
00210000 – 00220000, etc.
I then flashed these to the problem phone 1 at a time. All went well until I got to the block 00280000 – 00290000 immediately after this block was flashed the phone started making a clicking type noise & the LED’s were blinking on & off.
Removing the battery stopped this.
The clicking noise happened after flashing each block between 00280000 & 00300000 but each block appeared to flash ok with Rolis flasher 477 not reporting any errors.
Flashing blocks 00300000 – 00340000 went as normal with no clicking noise, but sadly after all this the phone still won’t power on.
I have been advised that the flash chip may be faulty hence the error message.
Is this the chip just below the on / off button?
Any thoughts anyone.
UB.
Old 08-01-2002, 14:36   #5 (permalink)
BufferMess's Avatar
Member: 9856
If you have sufficient equipment, you can change flash chip and try again.
Old 08-01-2002, 17:26   #6 (permalink)
Member: 14106
Hi,
That’s a bit too fiddley for me
UB
I need software for nokia 8210 flash to 8250 Terla Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 7 06-30-2002 11:41
New 8250 & 8210 flash problem B.H Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 11 03-08-2002 09:56
8210 flash Guesty Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 11-02-2001 09:37
8850 Flashed with 8210 flash file - Can it be fixed? JJ Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 03-16-2001 11:04
Page generated in 0.28427 seconds with 11 queries
