8210 goes blank if open message inbox Have some problem with an 8210. All function ok but always goes blank if I open message inbox. I tried to flash the mcu+ppm and write it with virgin eeprom. Phone working but still have the same problem. Any suggest ? Thx in advance |
Change display. |
Problem solved. Yes it wasdisplay problem.... thanks for the reply demon |
@bengong Change your LCD...... but dont use Original LCD, "pake Non_Ori aja" because i have 10000000x same problem Virus Infected...... :D :D :D |
@de echo yeah... problem solved by changing lcd, but i use original lcd ( orangnya mau, kenapa nggak ? :P ) btw where u come from echo (angku) ? I'm from sby |
hi all !! i also had solved this problem with 3 8250 and solved with reples lcd. i think it's only hardware problem. when i need about sw. i run to this forum. |
i have heaps of the LCDs with this problem for 8210 and 8250 Is there any way to fix this problem ? |
hi buddy-- the best way is to change the lcd- the problem caused is due to the capacitors on the upper portion of the lcd-- to repair them check some old posts in the hardware repair section-- once "vicky " has given some solution but i dont rememer that!! best regards gohar;) |
