Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L )
Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) Nokia Legacy Models Like 1011, 1610, 211x, 2x20, 6050, 3110, 8110, NKxxx , 2100, 3210, 3310, 3330, 3410, 5110, 5210, 5510, 6110, 6150, 6210, 6250, 7110, 8210, 8250, 8850 also 9110 & 9210
Old 09-29-2002, 18:57   #1 (permalink)
Member: 13453
Thanks Meter: 3
8210 goes blank if open message inbox
Have some problem with an 8210. All function ok but always goes blank if I open message inbox. I tried to flash the mcu+ppm and write it with virgin eeprom. Phone working but still have the same problem. Any suggest ?
Thx in advance
Old 09-29-2002, 19:24   #2 (permalink)
Member: 3528
Thanks Meter: 5
Change display.
Old 09-30-2002, 18:05   #3 (permalink)
Member: 13453
Thanks Meter: 3
Problem solved. Yes it wasdisplay problem.... thanks for the reply demon
Old 10-01-2002, 20:42   #4 (permalink)
Member: 13166
@bengong
Change your LCD......
but dont use Original LCD, "pake Non_Ori aja"
because i have 10000000x same problem
Virus Infected......
Old 10-02-2002, 20:46   #5 (permalink)
Member: 13453
Thanks Meter: 3
@de echo
yeah... problem solved by changing lcd, but i use original lcd ( orangnya mau, kenapa nggak ? :P )
btw where u come from echo (angku) ? I'm from sby
Old 10-03-2002, 18:30   #6 (permalink)
baraka42's Avatar
Member: 14578
Thanks Meter: 829
hi all !!
i also had solved this problem with 3 8250 and solved with
reples lcd. i think it's only hardware problem. when i need
about sw. i run to this forum.
Old 10-04-2002, 04:40   #7 (permalink)
Member: 3902
Thanks Meter: 19
i have heaps of the LCDs with this problem for 8210 and 8250
Is there any way to fix this problem ?
Old 10-04-2002, 05:57   #8 (permalink)
F C
F C's Avatar
Member: 6486
Sonork: 100.79846
Thanks Meter: 349
hi buddy--
the best way is to change the lcd- the problem caused is due to the capacitors on the upper portion of the lcd--
to repair them check some old posts in the hardware repair section-- once "vicky " has given some solution but i dont rememer that!!
best regards
gohar
be4 phone restarts while opening messages in inbox rushi Alcatel & TCL Old Models 2 03-17-2004 04:24
8210 goes blank after keypresses hakika Nokia Hardware & Hardware Repair 4 05-25-2003 21:37
8210e Inbox Problem - Screen goes blank Rebels Advocate Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 03-18-2003 04:36
8210 - no display in Messages/Inbox and Outbox ? Svetli Nokia Hardware & Hardware Repair 2 05-19-2002 01:27
8250v5.00 goes blank when go to inbox raddix2001 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 33 02-25-2002 09:53
Page generated in 0.30441 seconds with 8 queries
