03-28-2005, 08:00 | #1 (permalink) |
Freak Poster Join Date: Jul 2003 Location: cebu
Member: 35831 Status: Offline Thanks Meter: 4 | 8210 loosing signal. need help..... everytime i turn on my phone, it gives a full signal. then after 2 minutes, it will drop to 2 bars. then after a minute it will drop to ZERO signal.. then after 3 minutes, the signal will come back then drop to zero again. |
04-08-2005, 12:07 | #4 (permalink) |
No Life Poster Join Date: Nov 2001 Location: England Age: 41
Member: 7653 Status: Offline Thanks Meter: 823 | antenna switch, you can test if faulty. use sim card from network 900MHz band, then another from 1800MHz band (or any two band). if work on one then not other, your antenna switch fault antenna switch is just to "switch" between bands |
05-20-2005, 11:49 | #7 (permalink) |
No Life Poster Join Date: Apr 2005 Location: brunei
Member: 141262 Status: Offline Thanks Meter: 348 | additional!!! i also encounter that kind of problem!! yes its true all of your post are correct.. on my opinion do this on step by step basis... this is just a step by step strategy hope i doesn't get wrong... in your situation dropping signal but signal comes on and off... 1.)first is reheat PA.. test it... is still dropping... 2.) reheat cobba IC or audio IC... test it... still on / off signal... 3.) replaced the PA or power amplifier... test it.... still on / off signal.. 4.) replaced the cobba IC, sp unlock set faid etc.. test it... still no signal.... note:make sure that u use good and working IC/parts.. this solution doesnt work... nxt time ill post another solution... gud luck mate... |
06-02-2005, 01:14 | #8 (permalink) |
Cheater -Don't Deal with him- Join Date: May 2005 Location: London Age: 47
Member: 148419 Status: Offline Sonork: 100.999999 Thanks Meter: 54 | There are some filter capacitors near the antenna switch and hagar.Put some soldering flux with small brush and reheat that area it will be resolved. Best of Luck |
8210 no signal pls help | etcelfon | Nokia Hardware & Hardware Repair | 8 | 10-06-2004 09:31 |
8210 loosing signal after picking up the phone | hulala.[uk] | Nokia Hardware & Hardware Repair | 5 | 09-11-2003 19:07 |
8210 lcd problem need help | don_carleone | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 03-30-2003 05:08 |
8210 no network..need help | VREDNYJ | Nokia Hardware & Hardware Repair | 3 | 12-05-2002 10:42 |
