-   Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) (http://forum.gsmhosting.com/vbb/f131/)
-   -   8210 no network after flashing, look in (http://forum.gsmhosting.com/vbb/f131/8210-no-network-after-flashing-look-3165/)
simbirley 05-31-2001 15:10
I flashed an 8210 from 0020000-003d0000 as somebody had tried to unlock it from the wrong start address.
now there is no signal no matter which network it is on.
eg. it comes on and says orange then the network is lost and no calls can be made.
is there a solution to this?
the phone is version 5.25
wildwhacker 06-06-2001 00:18
DEPENDS WAS THIS A WORKING UNIT PREVIOUSE TO THE WRONG ADDRESS FLASH?
did you put the right version flash back in??
remove the front cover turn the unit on its front and look between the board and housing on the left you will see a gold contact coming from the aerial to the board. make sure it makes good connection with the pcb.
CHATAR 06-06-2001 02:23
no no no
dont loock for harware whyn you flash your phone with not originel flash
after flashing not netwerk
you most flash your phone back with the originel full flash
best regards
simbirley 06-06-2001 13:24
This should not be a flash problem as i have flashed it back with original backup.
there is just no network and it is not banned from any.
i will check the hardware thing though it was working prior to flashing.
Page generated in 0.14933 seconds with 5 queries
