Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L )
Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) Nokia Legacy Models Like 1011, 1610, 211x, 2x20, 6050, 3110, 8110, NKxxx , 2100, 3210, 3310, 3330, 3410, 5110, 5210, 5510, 6110, 6150, 6210, 6250, 7110, 8210, 8250, 8850 also 9110 & 9210
Old 05-31-2001, 15:10   #1 (permalink)
Member: 4398
Post 8210 no network after flashing, look in
I flashed an 8210 from 0020000-003d0000 as somebody had tried to unlock it from the wrong start address.
now there is no signal no matter which network it is on.
eg. it comes on and says orange then the network is lost and no calls can be made.
is there a solution to this?
the phone is version 5.25
Old 06-06-2001, 00:18   #2 (permalink)
Member: 3348
Thanks Meter: 3
DEPENDS WAS THIS A WORKING UNIT PREVIOUSE TO THE WRONG ADDRESS FLASH?
did you put the right version flash back in??
remove the front cover turn the unit on its front and look between the board and housing on the left you will see a gold contact coming from the aerial to the board. make sure it makes good connection with the pcb.
Old 06-06-2001, 02:23   #3 (permalink)
Member: 4378
no no no
dont loock for harware whyn you flash your phone with not originel flash
after flashing not netwerk
you most flash your phone back with the originel full flash
best regards
Old 06-06-2001, 13:24   #4 (permalink)
Member: 4398
Post
This should not be a flash problem as i have flashed it back with original backup.
there is just no network and it is not banned from any.
i will check the hardware thing though it was working prior to flashing.
No network after flashing U8500 with unlocked flash - What's wrong? James_S FuriousGold 9 05-10-2008 13:56
8210 no network after reflow badass639 Nokia Hardware & Hardware Repair 1 04-04-2002 15:32
8210 no network after MAD2 IC changed Chaku Nokia Hardware & Hardware Repair 6 11-12-2001 22:22
8210 no network after flashing, look in simbirley Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-01-2001 08:57
Page generated in 0.32567 seconds with 8 queries
