01-31-2005, 21:35 | #3 (permalink) | |
Insane Poster Join Date: Oct 2004 Age: 43
Member: 86070 Status: Offline Thanks Meter: 0 | Quote:
02-02-2005, 03:16 | #6 (permalink) |
No Life Poster Join Date: Aug 2004 Location: dasma cavite Age: 46
Member: 78367 Status: Offline Thanks Meter: 11 | solution on 8210 no power but charging and flashing due to water damaged!!!!!! 1. check lines between keypad possitive line #3 or #6, #9 and v360. if lines broken jump it wire. if not ok... 2.(this is important) there is a thin line horizontally parallel to the right side keypad #3, #6, #9 that is the only line between v360,#3,#6,#9 to the cpu. slightly scratch line test it if there is continuity... if there is not, jump it..... problem solved! note if there is continuity? hmmmmm MAD line are broken..... hope it helps.... |
8210 power off after ringing | Omda | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 09-03-2002 12:48 |
3310/8210 Power Amplify(P.A.) For Sell | acent | Main Sales Section | 1 | 07-22-2002 00:45 |
8210 power off when talking..... | ARC | Nokia Hardware & Hardware Repair | 4 | 11-29-2001 13:03 |
8210 powering off | GsMen | Nokia Hardware & Hardware Repair | 5 | 10-30-2001 12:35 |
8210 power problem | modcell | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-08-2001 14:05 |
