Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L )
Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) Nokia Legacy Models Like 1011, 1610, 211x, 2x20, 6050, 3110, 8110, NKxxx , 2100, 3210, 3310, 3330, 3410, 5110, 5210, 5510, 6110, 6150, 6210, 6250, 7110, 8210, 8250, 8850 also 9110 & 9210
Old 02-09-2003, 13:29   #1 (permalink)
Member: 12065
8210e Inbox Problem - Screen goes blank
Hi Everyone,
I am experiencing an odd problem with an 8210e. The problem is that when i go to the inbox to read a message the screen goes blank and the phone crashes.
I have tried flashing different software versions (The last one i tried was v6.01). I have erased the entire flash before flashing the new software just in case and have also used a virgin eeprom and an eeprom from another 8210 (with full software flash).
If anyone has any ideas why this is happening and how to solve it i would be gratefull for any help.
Rebels Advocate.
Old 02-09-2003, 14:17   #2 (permalink)
Allen's Avatar
Member: 2034
Thanks Meter: 24
Change LCD
CHEERS!
Old 02-09-2003, 14:22   #3 (permalink)
Member: 12065
I dont think its the LCD as all other menus and even the outbox and write message menus work.
I have a spare so i will try it anyway. You never know.
Rebels Advocate
Old 02-09-2003, 17:06   #4 (permalink)
zmicier's Avatar
Member: 6937
it'z LCD problem
phone hang up on Inbox and Picture messagez etc
Old 02-10-2003, 00:30   #5 (permalink)
Member: 12065
Your both correct,
I have changed the LCD to the spare and it now works fine. I did not believe that the screen would only freeze when viewing the inbox. Does anyone have any idea why this is?
Thanks for your help,
Rebels Advocate.
Old 02-11-2003, 17:34   #6 (permalink)
mobymaster's Avatar
Member: 13975
Thanks Meter: 7
It has happened to me many times.
Change it and all is OK
Old 02-16-2003, 06:07   #7 (permalink)
GALAXY*gsm's Avatar
Member: 16449
Thanks Meter: 39
100% display probleme we met this probleme many times b4..
good luck
galaxy
Old 02-17-2003, 00:36   #8 (permalink)
thecult's Avatar
Member: 9700
Thanks Meter: 62
@ Rebels Advocate ---> this is an old 8210 problem and solution is changing lcd 90% and 10% is lcd-rubber
best regards
Old 03-18-2003, 05:36   #9 (permalink)
Member: 22627
No rubber.....
These LCD-s were manufactured wrong. The driver unit bundled on the lcd is not able to process too much data.
If the rubber is the problem, the screen comes back, when you push the upper edge of the LCD gently.
When the LCD is the problem, the screenb only comes back after reboot.
Regards:
Bscorp
Nokia 3230 Screen Goes Blank help needed the_guru Nokia Multimedia 2 08-20-2007 06:26
Nokia 3230 Screen Goes Blank help needed the_guru Nokia Hardware & Hardware Repair 1 08-18-2007 13:55
2100 Screen Goes blank after 10 Sec zakiyyboss Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 02-21-2006 04:52
M55 screen goes blank afetr flashing E&D Siemens-Benq RingTones and WallPapers 2 11-03-2004 20:22
3330 screen goes blank after a while!!! LAD Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 09-04-2004 16:32
Page generated in 0.16012 seconds with 9 queries
