01-24-2004, 07:47 | #1 (permalink) |
Junior Member Join Date: Jan 2004
Member: 50207 Status: Offline Thanks Meter: 0 | After erasing flash 6110, phone dead I am a newbie here and just got the twister. However, I just use try an error to flash manual flash the phone 6110, the phone become contact service. So I try to erase the flash but it mention if you put wrong model, will damage phone. I click no but it still erase. Than, I try to flash it by flash and UI option, UI option fail come the message: M-Bus error, 1F 00 10 40 00 04 00 01 64 02 01 2D Bad Mob Ack.( The MCU:nse3nx05.48c PPM:nse3nx05.48c) For the result of twister suite, it stated: Detected: 1st Boot Ok 2nd Boot Ok, DCT3, MAD: 22 G-02, ROM: 3, BUS: 8 FLID: 00898892, Intel 28F800B3-T, I28f160.tia Software: Algorithm Ok, [9CE7] Area: 0x002C0000-0x002FFFFF Erased, Time: 00:04 MCU Flashing Completed, Time: 00:06 Area: 0x002C0000-0x002FFFFF Erased, Time: 00:04 PPM Flashing Completed, Time: 00:06 Flashing Completed, Rebooting Mobile Power Up / Init Local Mode Failed ! Set UI Defaults Failed Please help me. Millions of thanks |
01-24-2004, 08:38 | #2 (permalink) |
Junior Member Join Date: Oct 2003 Location: Romania Age: 42
Member: 41238 Status: Offline Thanks Meter: 0 | Try to use Rollis 477 or 479 other Nokia flasher software and write full flash(eeprom+mcu+ppm),and then update faid and repair imei with eeprom tool.100% works. good luck! |
01-25-2004, 16:59 | #4 (permalink) | |
No Life Poster Join Date: Jan 2003 Location: Hong Kong. Age: 47
Member: 19979 Status: Offline Thanks Meter: 116 | Quote:
01-26-2004, 00:27 | #5 (permalink) |
Member: 50207 Status: Offline Thanks Meter: 0 | Hello Syed, I use nokia tools by rolis to read the MCU eeprom the good phone and than write it to the dead phone but fail. I also try to use Knok Phoenix to reflash using 6110-ro3.fls to reflash it but also fail. Please advice. Thank you |
01-26-2004, 06:11 | #7 (permalink) |
Member: 50207 Status: Offline Thanks Meter: 0 | Hello Yanio, I haven't change the flash chip as I don't have it right now. BTW, before I try my twister flasher, the phone is in good condition and I just it to test my twister, but it come out this result. I had flash the wrong MCU before, but I already flash the correct one but wrong version. Phone can power up but show error of different version. I try to flash the correct version but the twister and other soft at the moment can't help. Please advice. Thank you. |
01-26-2004, 08:23 | #9 (permalink) | |
try to resolder flash IC and flash normal 1 MB flash file readed from any working flash.... u dont normally damage ur flash IC by flashin the phone....just need to flash it with proper flash file ...u can use Rolis for flashing phone !! WBR Syed | |
01-26-2004, 16:59 | #10 (permalink) |
Member: 50207 Status: Offline Thanks Meter: 0 | Hi all, I would like to say big big thanks to all of your help. I am very proud to be a member of this forum. Finally, I succesfully to reflash the dead phone. Totally, I reflash 143 times but 3 time error flashing. Phones is alive now. I still got some doubt is it my phones' harware problem or the twister/cable hardware problem as it take so many time to reflash it to get it success. Anyway, once again thank you all for your kind and helpfull people. Best regards |
N95 8G after erase flash.Phone only white srceen then restart! | Dung Yaiba | Nokia Base Band 5 ( BB-5 ) | 4 | 08-24-2009 08:46 |
3410 Dead after Erasing flash file | KimCarlo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-22-2006 14:03 |
7610 new flash chip phone dead after flash | mccm | Griffin | 1 | 12-24-2005 09:21 |
After Erase Flash N-gage (nem-4) Phone No Power On | H@idour | Twisterflasher | 2 | 03-13-2005 16:21 |
N6610 5.52 dead after erasing flash LP2002 | J-lock | Nokia Digital Core Technology 4 ( DCT-4 ) | 11 | 01-28-2004 13:36 |
