08-08-2001, 19:00 | #1 (permalink) |
No Life Poster Join Date: May 2001 Location: Manila, Philippines Age: 53
Member: 4408 Status: Offline Thanks Meter: 5 | Caller ID and TEXT ID in 9210... How to??? MEMORY IN USE SIMCARD ...but everytime I received a call or a SMS Message, it didn't show the sender or the caller's name... it shows only the Mobile Number, I did not explore yet the 9210 manual... ...It's not the same as the classic 9110, when you use the SIM card memory automatically every name was identified if ever someone in the phonebook made a call or send a messages to you... Any 9210 owner know how to solve this mystery... <img src="confused.gif" border="0"> <img src="confused.gif" border="0"> <img src="confused.gif" border="0"> <img src="confused.gif" border="0"> <img src="confused.gif" border="0"> |
08-09-2001, 03:22 | #2 (permalink) |
Member: 4408 Status: Offline Thanks Meter: 5 | Mystery solved!!! Aside from storing your contacts in the SIMCARD, 9210 have new MENU option of Copy & Move to a particular or new Data base, That's it folks... just been too excited... can't wait someone to reply in this topic... Thanks to the viewers... |
08-19-2001, 19:37 | #3 (permalink) |
Insane Poster Join Date: Jun 2001
Member: 5012 Status: Offline Thanks Meter: 0 | I have the same problem with you ,but now it happen more seriou that some time all the keyboard can not work so I have to power off the phone and on again <img src="frown.gif" border="0"> ( do any one know about this pan ? |
08-20-2001, 04:40 | #4 (permalink) |
Member: 4408 Status: Offline Thanks Meter: 5 | ...it seems that 9210 developer knew this, but someone in this forum said that 9210 must<br />be upgraded to high version... I frequently<br />experience that, even when browsing my inbox<br />in the outer keypads, it hangs but fortunately<br />after removing the battery it go back to normal...<br />9110 also have that problem... a computer<br />& cellphone in one... that's why maybe just<br />like ordinary PC with slower RAM... it hangs... |
08-22-2001, 21:00 | #5 (permalink) |
Major Poster Join Date: Jan 2001
Member: 3112 Status: Offline Thanks Meter: 0 | Hi!!! Perhaps this can help you: Sevice Bullentin SB009/11.07.01 Changes and corrections between software versions 3.18 and 3.54: - Cannot open embedded mail after deleted locally<br />- KerExec-Error in Mail-Recipient<br />- SMTP over TLS: sending fails if message contains attachment<br />- Telephone and Messaging Watcher crash if CMT is not switched on<br />- Call doesn't alert in PDA after reboot<br />- Log application says, that incoming answered call is 'missed'.<br />- Many numbers in telephone input field jamms whole device<br />- Changing ALS line won't be stored in SIM<br />- PDA side can be locked without lock code<br />- Network selection cancel incorrect<br />- Autolock periods "1 minute" and "2 minutes" don't work<br />- SIM change security on - Lock code asked only on CMT<br />- Pin code requested twice<br />- SMS application closed, when sending SMS on reply<br />- Opening Print dialog makes SMS viewer panic<br />- Screen does not blank (when cover open) if autolock is activated<br /> - Removing memory card when sent or received fax is in Desk as a link crashes the device <br />- Incoming call, no number -> Nokia tune is always played<br />- Restoring stops when MT call is received My 9210 works 100%, i encountered only a little bug when i want to out of word or excel without save i canīt exit. B.R.<br />AgA |
08-23-2001, 04:27 | #6 (permalink) |
Member: 4408 Status: Offline Thanks Meter: 5 | ...does nokia service center accepts...<br />upgrading? I experience many application<br />error with this version... <img src="mad.gif" border="0"> |
Can i repair vendor id and product id with 0000 values ? | sijibae | GSM Programming & Reverse Engineering | 0 | 03-06-2010 14:54 |
invalid imei and unknown id in iphone. how to fix | monsterpassword | iPhone 2 / iPhone 3G / iPhone 3GS | 3 | 03-18-2008 06:08 |
lcd contrast in 9210 how to adjust | NEON-GSM | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 06-17-2004 16:17 |
