05-11-2001, 17:14 | #1 (permalink) |
Junior Member Join Date: Jul 2000 Location: Quezon City, Philippines
Member: 1708 Status: Offline Thanks Meter: 0 | changing language I'm a newbie. I want to change the language on my 8210 phone. How do I do it? What software do I need? I have a flasher cable. Thanks. |
05-11-2001, 18:40 | #2 (permalink) |
Freak Poster Join Date: Jun 2000 Location: laguna,philippines Age: 48
Member: 1544 Status: Offline Thanks Meter: 1 | read old posts.. dejan mcu-ppm box is the only way to change language... wintesla plus special hardware will do too. or bring it to the nearest nokia service center. |
05-12-2001, 10:04 | #3 (permalink) |
Member: 1708 Status: Offline Thanks Meter: 0 | Hi, Salamat Pare. So does it mean that Dejan Cable is use for unlocking only and you can't use it for changing the language on the phone? Another questions, do you always need to get a backup from unlocked phone with the same version as the phone that you're unlocking?Does the phone version have to be the same, say Asian vers., Finland vers, or Germany vers. What's the difference bet. a backup flash file & a partial flash file that you can find in many sites? Sorry I'm quite new to this and quite understand about flashing pa. Salamat uli. |
05-12-2001, 18:24 | #4 (permalink) |
Member: 1544 Status: Offline Thanks Meter: 1 | i might say yes... well dejan can unlock and make back-ups, can fix contact service in some cases but not always... backups should be the same, ppm w/c means the language and ofcourse the version... ppm should match the one stored in cobba of phone... untouchable part of phones without special hardware..if it doesnt match... it may result in network problem.. so that means u connot flash a phone with different version... as in upgrading... cira ang phones mo... ppm and the version of the phone is stored in 3 different places i think... and all should match one another... as well as the IMEI... partial flashes are use to unlock phones.. regardless of ppm ... while in backups... ofcourse for backups--- ppm should be the same with the phone that u will flash... hope i was able to help you... happy unlocking... ingat lang.. |
05-13-2001, 09:18 | #5 (permalink) |
Member: 1708 Status: Offline Thanks Meter: 0 | Hi Rothmanns, Thank you for your reply. What if I can't get a phone with open-line and with same ver. as the phone I want to unlock. Can I just get a partial flash with the same ver. from the various GSM website and then flash it to my phone? Do you mean that aside from the phone ver., example, 8210 ver. 5.25, the language ver. should be the same? I'm quite confused here. |
05-13-2001, 15:58 | #6 (permalink) |
Member: 1544 Status: Offline Thanks Meter: 1 | in unlocking... if your going to unlock a phone eg. 8210v5.11... you can use any partial flash file for 8210v5.11 found anywhere in the web... for backups... you have to use full backup for 8210v5.11with the same language... regardless wheather its openline or not... you can unlock it later on... |
05-22-2001, 02:23 | #10 (permalink) |
Junior Member Join Date: Jan 2001 Location: Benophorayia
Member: 3145 Status: Offline Thanks Meter: 0 | to rothmanns: hi and what do you think about http://gsmfree.rulez.at/viperbjk/manual.html??? are you thinking that`s not possible? i`v not try this sol, haven`t any 6210, but i`v try to use it with a downloaded backup and it looks like wery good idea. what u mean? h. |
05-22-2001, 19:15 | #11 (permalink) |
Member: 1544 Status: Offline Thanks Meter: 1 | hnedotuk, in talking about newbie stuffs here, i havent tried this software so i cant confirm if its working or not... why dont you try it first and tell us if its working or not... try to change the language of ur phone.. and tell me if its working 100%... the software didint mention its working on 8210.... as far as im concern.. only dejan 104 plus his box and the oroginal nokia box is the only way to change language correctly... i dare u to try it.... |
05-22-2001, 23:19 | #12 (permalink) |
Insane Poster Join Date: Mar 2001
Member: 3631 Status: Offline Thanks Meter: 0 | Well officially it does not work to change Language. But we are testing it right now. Result : 1. Successfully changed 6210 V3.01 C to J 2. Language Strings can also be changed, worked. to 1. : Not included right now in our tool. We've got to test it with other phones. Version Update/Upgrade is not possible ! to 2. : Using a Hexeditor and our tool for fixing ppm checksum it works already. Cya, Viper BJK P.S. : Our tool also worked well for 8210 (100%) and 3310 (but here second Eeprom checksum is invalid because of different fieldlength) <FONT COLOR="#ffff00" SIZE="1">[ 23 May 2001 00:21: Message edited 1 time, lastly by Viper BJK ]</font> |
05-27-2001, 16:46 | #13 (permalink) |
Member: 1544 Status: Offline Thanks Meter: 1 | ive tried ur tool in resetting security code on 6210 and it works well... but about the language... thats why i dare that guy to try it on his phone in changing language... more power viper and gang |
05-29-2001, 23:12 | #14 (permalink) |
No Life Poster Join Date: Jan 2001 Location: Madrid, Spain
Member: 3075 Status: Offline Thanks Meter: 2 | After 5 days testing languaje change in 6210 v502 I can say that this tool doesn´t work in 6210 phones for languaje changing. I used the ppm of http://www.volny.cz/holubice/ with the right address 00520000-005A0000 (524.288 bytes), flashed in my phone, read it, corrected with Veper tool, saved and test...... result... phone working with the new PPM but no signal and reseting it self. After that I tried with other PPM`s of the same version, 502 reading the PPM part of the phone and also reading of a full file editing with an Hex.editor and saving. The results are the same, changing of PPM but no network and reseting the phone. BR to all. |
last vers. editor problem_not change language name and language reset code | osom | Infinity-Box | 0 | 04-04-2008 17:18 |
can i change imate jam 2003To2005 and how change language to arabic | gsm4libya | JAFWM | 1 | 12-15-2006 13:17 |
Change language with Language Editor on SX1?Need master help. | stylius | E-Gold Based Phones | 1 | 08-23-2006 21:10 |
Change Language in 6110 | jonwillow | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 01-14-2000 05:04 |
Can i change language in the 688 by changing new EEPROM file | duyphuc | Old Ericsson Phones & Sony Phones | 1 | 06-17-1999 15:42 |
