Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L )
Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) Nokia Legacy Models Like 1011, 1610, 211x, 2x20, 6050, 3110, 8110, NKxxx , 2100, 3210, 3310, 3330, 3410, 5110, 5210, 5510, 6110, 6150, 6210, 6250, 7110, 8210, 8250, 8850 also 9110 & 9210
Old 12-20-2004, 11:06   #1 (permalink)
Member: 99113
Thanks Meter: 2
Post Contact Service In Nokia-2100
I Have A Problem With A Contact Service In Nokia-2100.
After Sucessfully Completed The Adopted Procedure In Ufs-3,( Like Select The Model No, Select Mcu File, Select Ppm File Then Press Flash) But Dislpy The Same As Contact Service.how Can I Do To Solve The Problem. Kindly Guide In This Matter.
Thanks
Rajesh Kumar Jain
Old 12-20-2004, 12:38   #2 (permalink)
Registered User
taihv's Avatar
Member: 40808
Thanks Meter: 10
After fullflash it always say CS, just unlock it pls!
Old 12-20-2004, 18:39   #3 (permalink)
Member: 99113
Thanks Meter: 2
please understand to me in details.
Old 12-20-2004, 19:29   #4 (permalink)
lypen17's Avatar
Member: 44223
Thanks Meter: 20
unlock it by eeprom tools 3.1
Old 12-21-2004, 17:35   #5 (permalink)
Member: 99113
Thanks Meter: 2
Thanks
Rajesh Kumar Jain
Old 12-22-2004, 04:58   #6 (permalink)
Registered User
taihv's Avatar
Member: 40808
Thanks Meter: 10
Do as i said: unlock ur phone!
Old 12-22-2004, 18:33   #7 (permalink)
Member: 84028
I am facing same problem. Would you pls tell me the procedure of UNLOKING by UFS3 ?
Old 12-23-2004, 04:51   #8 (permalink)
Member: 64449
Thanks Meter: 2
Could or does anyone have the sollution to this problem? A working sollution please!
Old 12-28-2004, 22:19   #9 (permalink)
pava's Avatar
Member: 80567
Thanks Meter: 53
first write eeprom after that full flash then unlock,faid ,full factory default and its work.USE KNOK
Old 12-29-2004, 03:14   #10 (permalink)
Member: 33043
check u r imei.... usually imei is changed after flashing. use the knok or any other program for dct3 to unlock, change imei..use nokia 8210 cable. works 1000% unless bga is faulty.
Old 12-29-2004, 08:31   #11 (permalink)
.:RAGE:.'s Avatar
Member: 77205
Thanks Meter: 4
hi friend,
2100 contact retailer.... you must change flash ic my friend
after changed the flash you must flash the mobile and writethe original imei
set faid, unlock, fullfactory default...
happy new year!!!!!
Old 12-29-2004, 09:04   #12 (permalink)
Member: 79888
use the nokia tool forthe contaqct saervice,
Old 01-25-2005, 10:16   #13 (permalink)
Member: 65774
Thanks Meter: 4
Please guys dont waste ur time with all that just read any flashfile from a working 2100 and write it to ur phone using a geoflash tool after it will still display contact service use rolis to write back its original imei and everything will be okay.
Old 01-25-2005, 10:40   #14 (permalink)
nafie's Avatar
Member: 69693
Thanks Meter: 6
after flashing with ufs , rebuilt imei first then reset all the ui settings....... i use to have same problem but after taking this procedure no problem so far
Thanks
Rajesh Kumar Jain
Old 01-26-2005, 10:09   #15 (permalink)
Member: 41105
Thanks Meter: 43
@Rajesh Kumar Jain
The MCU and PPM version must be same verion or the eeprom (emulated in flash) or imei is damaged like 65656565656565 or 00000000000000000. If the imei is ok and after you rewrite firmware and problem persist change the flash and write the original imei back and make update faid and full factory reset
ENJOY
Contact service in Nokia XpressMusic 5130! Gestapoz Nokia Hardware & Hardware Repair 0 01-19-2010 19:52
whats the best method to solve contact service in nokia 5130 etc obioha MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 11-28-2009 07:58
Very strange CONTACT SERVICE in Nokia 3120 Badra n-Box 2 08-11-2008 12:46
contact service in 3310,2100,3410 uncle smallz Nokia Hardware & Hardware Repair 12 04-07-2007 14:26
Contact Service in Nokia 1600?? WAHID2 n-Box 8 01-28-2007 08:29
Page generated in 0.24906 seconds with 9 queries
