08-04-2002, 19:18 | #1 (permalink) |
Junior Member Join Date: Aug 2002
Member: 14343 Status: Offline Thanks Meter: 0 | contact service nokia 3210 After 2 years of normal operation, one morning when switching on the "contact service" message appeared. If after several trials it turns on normally, then in just about 30 seconds switches off, again. Has anybody got any such bad experience with Nokia 3210? What should I do to make it work again? Nokia service is out of question because they are so expensive I can buy a new 3310 on sale for their repair price. I am interested in solving this problem all by myself with your kind assistance! So, any good advice is highly appreciated! Send your reply to: [email protected] Regards for all, bt2002 |
08-05-2002, 04:07 | #2 (permalink) |
Junior Member Join Date: Dec 2001 Location: South Africa
Member: 8070 Status: Offline Thanks Meter: 0 | Hi I also had a 3210 with the exact same problem. What i did was, i ran NK_CALC and repaired the eeprom (F1), it removed the contact service, and the fone worked perfect. If that doesn't work, then all you have to do is flash the fone with a repair flash or full flash (calculate FAID after that), and your fone will be back to normal. Good Luck Cheerz |
08-05-2002, 13:35 | #3 (permalink) | |
No Life Poster Join Date: Jan 2002 Location: MARS
Member: 8304 Status: Offline Thanks Meter: 362 | Quote:
HOW? 1 - POWER UP PHONE TILL IT DISPLAYS 'CONTACT SERVICE' 2 - CONNECT PHONE TO CABLE 3 - CLICK TEST CHECK BOX 4 - PROGRAM WILL SHOW THE REASON FOR 'CONTACT SERVOCE' 5 - NOW YOU CAN TELL IF IT'S HARDWARE OR SOFTWARE HINT: 1- IF PROGGIE SHOWS E.G 'EEPROM TUNE CHECKSUM TEST FAILED',YOU KNOW THAT CHECKSUM VALUES IN EEPROM NOT O.K.SO YOU REPAIR EEPROM CHECKSUM 2 - IF PROGGIE SHOWS E.G 'CCONT INTERFACE TEST FAILED',IT'S A FAULTY CCONT I.C,ETC,ETC. 3 - BLA BLA BLA BLA 4 - YOUR PHONE IS FIXED | |
08-05-2002, 20:16 | #4 (permalink) |
Member: 14343 Status: Offline Thanks Meter: 0 | re:re: contact service nokia 3210 Many thanks! It seems to be working! After the test the message was: "CCONT INTERFACE TEST FAILED! PLEASE REPAIR THE PHONE FIRST!" Unfortunately, I am a complete novice in GSM so I badly need further guidance! Is it an IC failure or software? How to proceed? Can I make it without going to service? Your further help is very precious. Thanks once, again and I am looking forward to receiveing further instructions! Many regards, bt2002 |
08-28-2002, 14:58 | #6 (permalink) |
Member: 14343 Status: Offline Thanks Meter: 0 | Hi, It is a software problem. Find the program EEPROM TOOLS BY B-PHREAKS on the Net. Apply it to your phone step by step as advised, but first for further advice contact directly Mujie, he seems to be an expert in this issue. Regards |
08-29-2002, 15:51 | #7 (permalink) |
No Life Poster Join Date: Jul 2001 Location: RP Age: 48
Member: 5246 Status: Offline Thanks Meter: 9 | @bt2002 You have to REFLOW your CCONT IC using a hot air rework station and good flux to restore broken/cold soldering under CCONT IC. @ boy 2000 You can repair eprom tune checksum of 32, by reprogramming the 24c128 eprom using an external eprom programmer and software. |
contact service nokia 3410 | afrodita | UFS2 + UFS3-Tornadoflasher | 6 | 04-02-2004 20:24 |
contact service nokia 3410 | cdm05 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 10-23-2003 10:10 |
contact service nokia 3110 | iki_tenggo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 03-17-2003 03:21 |
Contact Service on 3210 | Zarkov | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 12-21-2001 21:29 |
Contact Service on 3210 v5.36 * HELP * | kick | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-26-2001 02:38 |
