01-30-2001, 00:17 | #1 (permalink) |
Freak Poster Join Date: Dec 2000 Location: Portugal
Member: 2785 Status: Offline Thanks Meter: 0 | CS problems with dejan flasher after that, i managed to retrieve the flash. tried to upload the flash again, but CS remained. then i tried to upload the full backup from fatum's site (5110 5.11) and the phone powered on, with no contact service. but this time, no network i think that the problem is in some part of my flash file. how can i repair this? how can i locate the damaged bytes in flash? please help guys. Y2K, Cyberdog, Blu3fish, everyone!!! HELP!!! this is something i was not expecting. thnx in advance Dark Lemming |
02-02-2001, 06:20 | #4 (permalink) |
Insane Poster Join Date: May 2000 Location: CZ
Member: 1326 Status: Offline Thanks Meter: 0 | hey guys, why you didn't used nokiatool 034 for unlocking v05.11, it's fast and save I think... I'm using flashing only if it's necessary and there is no other way...for v05.29 and higher.. ~ChM |
02-02-2001, 12:27 | #5 (permalink) |
Junior Member Join Date: Jan 2001 Location: GLASGOW,UK
Member: 3186 Status: Offline Thanks Meter: 0 | hi D L .. try this .... 1) put original backup into your phone... 2) now read your phont again but in 4 chunks ... (remember to rename the flash.out after each chunk) 00200000-00280000 00280000-00300000 00300000-00380000 00380000-00400000 3) now put fatums backup into handset 4) try puting one of the backup chunks into your phone at a time. 5) see when contact service pops up! 6) now you know which block its in .... 7) with the faulty block in your phone, read that block as smaller blocks .... 8) till you get to the 65536 byte block that is giving you trouble 9) now if i am correct the block will have some bytes ff ff ff fe ff ff, try changing the odd byte to ff using hex editor 10) load you original phone backup, then the new 65536bytes edited file and the message should be gone. i have this problem on a 7110 and 8210 and corrected it this way. YOU know that the signal is not there because the imei in the eeprom and the imei in the flash dont match ... in a phone that old have you tried bartek imei changer 1.2 on the eeprom bin file ? ok friend i leave you to try this ... let us know how you got on . ------------------ BEST OF REGARDS TO ALL KIANI |
problem with dejan flasher | Vigilius | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-05-2001 19:37 |
Problem with Dejan Flasher | mrlooper | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 12-01-2001 03:20 |
Problem with Dejan Flasher 1.00b | milerr | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 09-03-2001 18:59 |
Reading problem with Dejan Flasher | Dodo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 02-15-2001 15:53 |
Problems with Dejan Flasher with new Versions | Murat Bekar | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-21-2000 22:07 |
