05-25-2007, 08:30 | #1 (permalink) |
Freak Poster Join Date: Aug 2003 Location: India Age: 50
Member: 37352 Status: Offline Thanks Meter: 278 | DCT-3 Common Problems Part -Common Problems Flash ic -auto reset (test w/ sim and without sim) - unknown flash - unable to write -writable but unable to power on - cant write imei (for internal eeprom only, if external then its eeprom chip) -with power but can't read by mbus/flasher device - read flash at first byte(address at 0x20001 then stop - when writing always display "battery voltage is too low. SRAM-No Power - Ram is Bad (Test with Banana Flasher) - Read and Write Flash but unable to power on - Auto off, when trying to power on again, unit can't power on.waiting for a few minutes to power it on. - writng flash,but cant detect by flasher device,empty. - in 3210 reading/writing stop. Cobba -no power if shorted (test it by hang method) -contact service (serial/parallel) -no signal a.no rx (receive) b.no tx (transmit) c.intermittent signal d.fluctuating signal -signal stable but cant reach when trying to call, cant send sms, cant make a call -no audio (earpiece/*****piece) -garbled audio -cant unlock (openline) -sim card not accepted always appear -auto reset (test with simcard only) CCONT-No power - No Signal a.no rx b.no tx c.fluctuating -insert sim card -writing flashing error -always hang (jammed) - auto off (with sim and without sim) -no display -contact service -no ui interface (blight,buzzer, vibra) -with power but cant read by mbus flasher device HAGAR -No Power -No Signal a.No rx b. no Tx c.Fluctuating d.Intermittent -Auto off when receiving signal or after receiving signal -Hang then off. PA-No transmit-No Rx if overcurrent -Auto off when making a call, or before entering menu -no Power if shorted -Short battery standby time (fast drain) -Weak Transmit Crystal osci (13/26 Mhz) -No Power -No signal -Auto off -Hang Clock Crystal-slow/too fast ringing tone-slow/too fast clock timing -intermittent signal -no power if shorted Antenna Switch-No RX -No TX -Fluctuating Signal -Intermittent Signal This is not a complete solution.its just additional info, or maybe some reviews for our expert one, if you find some errors, just correct it.ill be glad to learn a new one. if u hav additional info, just add. Thanks br. ( Thanks to "YETYET") |
The Following User Says Thank You to hangout2511 For This Useful Post: |
Nokia DCT 3 Problem With UFS - 3 | PhonePlus | UFS2 + UFS3-Tornadoflasher | 2 | 07-23-2004 10:33 |
Problem with Flash DCT-3 / 3310 | MisterX GSMFREE | Twisterflasher | 33 | 04-16-2004 18:21 |
hot dct 3 flash problem | DarkSkir | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 03-15-2004 16:01 |
DCT-3 RF Problems procedure | Burnt Cobba | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 10-11-2002 14:05 |
SIgnal problem in DCT-3 phones. | kingofhearts | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 08-01-2002 03:46 |
