02-14-2002, 21:26 | #1 (permalink) |
Freak Poster Join Date: Oct 1999 Location: CZ Age: 55
Member: 564 Status: Offline Thanks Meter: 2 | DejanBOX works, but MBUS not read phone info. I succesfully program PIC16CE625 with ProPIC programmer. I connected box to PC, started NK_FL1.05. Box info display "1.02.5001".<br />But when I trying read log from phone, display message "Bad connection" I thing MBUS comm.not work. Why ?????? <img src="frown.gif" border="0"> <img src="frown.gif" border="0"> <img src="frown.gif" border="0"> <img src="frown.gif" border="0"> <br />Nk flasher 1.0b read phone with the same cable O.K. Thanks for help MP |
02-14-2002, 23:22 | #2 (permalink) |
No Life Poster Join Date: Sep 2001 Location: Portugal Age: 49
Member: 6156 Status: Offline Thanks Meter: 3 | What if you update the phone on non-automatic mode? will it flash? I have the same problem on windows... If I exit to DOS and run a dos extender (cwsdpmi) it works fine... |
02-15-2002, 00:17 | #4 (permalink) |
No Life Poster Join Date: Nov 2001 Location: Europe
Member: 7690 Status: Offline Thanks Meter: 4 | Hi ALF SEND me this DOS Extender cwsdpi<br />thanks -=G3=- <img src="tongue.gif" border="0"> [email protected] |
02-15-2002, 00:23 | #5 (permalink) |
Member: 7690 Status: Offline Thanks Meter: 4 | Hi MP!!!!!!!!!!!!!! What is ID in propic2 LPT programmer????????<br />How RESET the PIC?????????<br />==========================================<br />thanks 1) Program blank chip with the new HEX file (Dex1.HEX) <br /> <br />2) Put the chip in place where it'll be working for at least 1 second. <br /> If you use the same board please ensure that the power supply goes to the chip for at <br /> least 1 second. Ideally - put the chip into standard 5V power supply working condition for <br /> PIC (4 - Reset, 5 - GND, 14 - VCC, 16 - 4MHz external clock or crystal between 15&16), <br /> switch power supply ON, ((((((((((((((((((((((((RESET PIC))))))))))))), wait 1 second, switch OFF.<br /> At this point the Data memory is programmed.<br />3) Insert chip again into programmer and program it with the Dex0.HEX file. <br /> The programmer will tell you about ERROR for last memory locations - no problem, it's OK. During programming please set the next parameters for Configuration Word (CFGW):<br />Oscillator (FOSC): XT<br />(WDTE): Disabled<br />(PWRTE): Enabled<br />(BODEN): Disabled<br />(CP): Disabled Best Regards<br />-=G3=- <img src="rolleyes.gif" border="0"> [email protected] |
02-15-2002, 00:51 | #7 (permalink) |
Member: 6156 Status: Offline Thanks Meter: 3 | Here it is: <a href="http://alf.di.fct.unl.pt/~pa/CWSDPMI.EXE" target="_blank">cwsdpmi.exe</a> Run as "cwsdpmi -s- -p" before running flasher... If you don't have much physical ram run as "cwsdpmi -p" About M2BUS for me it only does not work in a DOS box running on Windows... WinDLS works great, so MBUS works for me... Try WINDLS 2.7 (free version) and tell me if it works.. |
02-15-2002, 02:57 | #10 (permalink) |
Junior Member Join Date: Jan 2002 Location: SPAIN
Member: 8842 Status: Offline Thanks Meter: 0 | Witch Software and HArdware have you used to program the pic 16ce625 we want to start experiment but need this info to go on, ge can get now this pics but need soft to program an cheap hardware to make or buy here in spain... <br />Any idea please, , , thanks <img src="rolleyes.gif" border="0"> <img src="tongue.gif" border="0"> <img src="rolleyes.gif" border="0"> |
02-15-2002, 07:16 | #11 (permalink) |
Member: 564 Status: Offline Thanks Meter: 2 | To Alf: Thanks for your reply. When I press F2-manualy updated flash, phone is flashing O.K. <img src="redface.gif" border="0"> After rewrite flash, power ON the phone, Enter and message "Bad connection" .<br />I don't have Windls prog. for testing. I'll try in DOS mode.<br />I have chip 16CE625 - JW. I have 4MHz crystal. To G3:<br />Thanks for reply to. <br />What about ID in ProPIC ?<br />I reset chip with connecting GND on pin 4. Regards MP |
02-15-2002, 07:54 | #12 (permalink) |
No Life Poster Join Date: Jan 2000 Location: GSM Forum
Member: 871 Status: Offline Thanks Meter: 602 | Hello, Dejan Program inside PIC does not work with 4Mhz<br />Crystal Oscillator. Please follow the schematics<br />because that is all you have to do... (8Mhz xtal). If you use 4Mhz Xtal, you will only get BOX ID <br />and limit function working, all the rest will not <br />work! Best Regards,<br />X-Shadow |
02-15-2002, 10:08 | #14 (permalink) |
Freak Poster Join Date: Nov 2001 Location: india
Member: 7176 Status: Offline Thanks Meter: 0 | so which ic should we use pic16c625-04p or pic16ce625-20p [email protected] |
02-15-2002, 13:23 | #15 (permalink) |
Member: 6156 Status: Offline Thanks Meter: 3 | If flashing works then use WinlDLS 2.7 (it's free and downloadable everywhere) to calc the FAID. Works for me and should work for you even at 4Mhz... About using a 4Mhz crystal... Try to use an 8Mhz one, even if you have a 16ce625-04... I've seen reports that it works... The PIC that should be used is the 16ce625-20 with an 8Mhz crystal. [ 15 February 2002: Message edited by: Alf ]</p> |
can read detailed info, but can not read general info | kibsoft | Infinity-Box | 3 | 11-15-2009 20:44 |
i have a probleme with bb5 phone, hwk cant read phone info corectly | yassinek85 | HWK | 8 | 10-27-2009 04:58 |
MT-BOX can not read phone info of some models! | KUBAT1 | MT-BOX | 7 | 04-23-2007 11:15 |
MyC-3b: can not read phone info with SWS!!!!! | taihv | SagMaster Team OLD Products | 0 | 04-24-2005 06:22 |
FBUS works but MBUS not! PLS Help! | Upo | Nokia Hardware & Hardware Repair | 5 | 09-12-2000 14:54 |
