09-19-2001, 14:38 | #1 (permalink) |
Freak Poster Join Date: Aug 2000
Member: 1925 Status: Offline Thanks Meter: 1 | display 8210 I have a problem with my 8210. The display doesn't work. Sometimes I can see it but most off the time it's gone. Or it gets a bit weird, as if the phone throws all the pixels through eachother.<br />I already tried to clean the contacts, and to tighten the screws a bit more, but nothing helps.<br />Is it the display that is broken, or is for example the software of the phone not alright? Can somebody help me? Regards Alfons |
09-20-2001, 09:01 | #3 (permalink) |
Member: 1925 Status: Offline Thanks Meter: 1 | You say: change the displaycontacts, but what do you mean by that?<br />I can change the whole display, including frame, but I can't change the contacts, can I?<br />And if yes, where can I get these contacts? Best Regards Alfons |
09-25-2001, 05:28 | #5 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Philippines
Member: 4274 Status: Offline Thanks Meter: 18 | check if your LCD had two SMD capacitors at the back... if yes, then that two capacitors can be the possible problem that causes your display to come and gone... |
09-25-2001, 12:15 | #6 (permalink) |
Freak Poster Join Date: Nov 2000 Location: Sweden
Member: 2628 Status: Offline Thanks Meter: 0 | try first to check the cond, back, if u still have same problem so change the display, it may have been that it have got some "crazy things". But check the thing around the display first, I meen, the contact etc!!! <br />Good luck! |
09-25-2001, 14:22 | #8 (permalink) |
Member: 1925 Status: Offline Thanks Meter: 1 | Thanks guys for your replies! I have already ordered a display, incl. a complete frame. I guess that should do it anyway.<br />But Ambot, there are indeed two SMD capacitors at the back. But my display doesn't come an go now, it's just that some lines aren't displayed. Could it be those two capacitors?<br />Well, thanks anyway Best regards Alfons |
09-25-2001, 17:49 | #9 (permalink) |
No Life Poster Join Date: Jun 2001 Location: Philippines Age: 47
Member: 4873 Status: Offline Thanks Meter: 5 | Lines in the lcd cannot be repaired.. except if the elastomer are just loose or dirty... these lines came about by pressure on the lcd or fallen 8210 <img src="smile.gif" border="0"> Just have to replace the lcd man |
display 8210 | Lord_of_boards | Nokia Hardware & Hardware Repair | 2 | 03-14-2002 01:43 |
Display 8210 - 8250.... | Andyx | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 10-20-2001 23:51 |
8210 - change display | laxxe | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-15-2001 12:03 |
8210 Display problems | simonb | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 04-30-2001 10:17 |
display on 8210 | vampire | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-22-2000 09:42 |
