01-23-2001, 12:50 | #1 (permalink) |
No Life Poster Join Date: Nov 2000 Location: EGYPT Age: 44
Member: 2583 Status: Offline Sonork: 100.88702 Thanks Meter: 203 | eeprom checksum , mcu rom checksum !!!!! 1 - 3310 contact service ver 3.24, wintesla tests result is : MCU ROM CHECKSUM (Failed) . 2 - 8210 contact service ver 5.16, wintesla tests resul is : eeprom sec checksum (Failed) . ( i tried on 8210 contect service repairer by X-Shadow but i got eeprom Empty , when i tried with another working phone and its ok ) i need to know : 1 - whats the diff between MCu rom checksum and eeprom sec checksum . 2 - contact service repairer by x-shadow will work with which ? ( is it eeprom sec checksum ? ) Thanks All |
01-23-2001, 15:24 | #2 (permalink) |
No Life Poster Join Date: Jan 2000 Location: GSM Forum
Member: 871 Status: Offline Thanks Meter: 602 | Hello Meshoz, Yes, security checksum is in EEPROM... But for 8210 EEPROM is emulated in flash, so you can fix this without opening unit by following my instructions. But if you say EEPROM is empty, why empty??? is it FF FF FF FF FF FF or something else??? Maybe you just need to put soldering flux around the BGA ICs and heat it with hot air set at 2.5. Most of 8210 I fix have this problem, but all is ok after heating the BGA Chips. For 3310, there is a solution for your contact service unit. Please do not try to put different flash from different phone or else you will destroy it like what you did to your 3210. Email me, and I will tell you how to fix it... Best Regards, X-Shadow |
01-23-2001, 18:22 | #3 (permalink) |
No Life Poster Join Date: Sep 2000 Location: UK York Age: 56
Member: 2008 Status: Offline Thanks Meter: 4 | Hi X-shadow I have same problem with 6130 4.15 "CS" Wintesla says MCU ROM Checksum Fail Is this repairable I have Original Backup 20000-40000 And byte for byte is the same as Phone but still gives "CS" Can you help its nott urgent its just educational to know why this has happened. Cheers Charlie |
01-24-2001, 19:52 | #4 (permalink) |
Crazy Poster Join Date: Dec 2000 Location: Sweden
Member: 2806 Status: Offline Thanks Meter: 0 | Hi Meshoz and x-shadow, im very intressted in x-shadows contact service prog. does it work ? i would be very happy if any of you would send it to me ------------------ [This message has been edited by Leeloo (edited 25 January 2001).] |
01-25-2001, 00:44 | #6 (permalink) |
Insane Poster Join Date: Nov 1999 Location: Cebu City,Philippines
Member: 682 Status: Offline Thanks Meter: 0 | Hi, Can someone help me, I got a 3210 in Contact service after partial flashing.I've got back-up from 200000~4000000 and flash it back to phone but phone is still in "CS".Has someone have solution on this. Pls.. HELP!!! [email protected] |
3310 MCU ROM checksum error | baz_thrower | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 05-28-2003 23:17 |
3410&3350 and others MCU/PPM checksums | Eerchant | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 10-10-2002 10:48 |
Bad MCU flash checksum-3310v5.47??? | robbie | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 05-14-2002 23:43 |
Bad MCU flash checksum-3310v5.47??? | robbie | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 05-14-2002 02:38 |
MCU+PPM checksum Algorithm NEEDED | MySweetyLove | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 03-15-2002 11:55 |
