03-15-2001, 16:03 | #2 (permalink) |
No Life Poster Join Date: Jan 2000 Location: GSM Forum
Member: 871 Status: Offline Thanks Meter: 602 | Hello... EEPROM in 3310, 6210, 8850, 8210 are similar to EEPROM content of 3210, but of course not 100% the same. You can use Checksum calculator programs with them like Guar if you cut the EEPROM into same size as 3210 which is 16KB. You must of course know first how to cut EEPROM in 003D0000-00400000. The first checksum is the same with 3210, but the second checksum is NOT THE SAME Location as 3210. So you can only fix first checksum... SP-Lock Data is similar to 3210 as well as first and second IMEI. [Correction to mistake before] Some time ago, I said that if you flash 3310 Korea (asia version) with 3310 Finland (Europe version) flash file to address 00200000- 00300000, you will get animated Hands start-up logo to your phone... This was a mistake and this is snot true... Sorry, but it was just recent that I realized that even 3310 Korea made have already animated hands start-up logo beginning 4.06 and up! The logo is obviously found in the EEPROM and can be disabled and enabled using some HEX editing. To give you an idea, try to read 003d0000-0040000 of a 3310 with animated hands, save it and then run Nokia Tool and apply the factory defaults setting to UI. Notice that you will loose the animated hands logo. So read again 003d0000-00400000 and compare it with the original Maybe someone should make an animated logo uploader for 3310 even if we have to manually edit the HEX in the EEPROM. I think it uses 3 frames like animated GIF. Best Regards, X-Shadow |
03-15-2001, 21:41 | #4 (permalink) |
Freak Poster Join Date: Dec 2000 Location: UK
Member: 2752 Status: Offline Thanks Meter: 0 | Hi, From your post are you saying that by applying the Special Factory Settings (Defualt UI) with Nokia Tool 034 that the animated logo can be removed? I have a few friends who would like to change their start up logo but can't because of the animated logo. Does anyone know where I can find info about the uses of all of the other settings in Tool 034 ------------------ Syko [email protected] |
03-15-2001, 23:51 | #5 (permalink) |
No Life Poster Join Date: Sep 2000 Location: UK York Age: 56
Member: 2008 Status: Offline Thanks Meter: 4 | Hi all Am I on A diffrant planet or have I got hold of the wrong end of this conversation. X-Shadow is saying when you have removed Animated logo with programs available EG: Logomanager 1.18 you cannot put animated logo back but if you can modify the bytes in Emulated EEprom for animated logo you would be able to put it back. In other words there is no problem taking it off, and putting any logo on startup screen the problem is putting the sodding thing back Regards Charlie |
NEEDED: Website designer/Graphics designer | Exodusnz | Job Opportunities / Vacancies | 4 | 05-11-2010 09:10 |
Sorry guys but i dont understand about inserting ppm and mcu by dejan 1.00+ppm cutter | Abe | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-01-2001 03:03 |
Help! I nothing can not understand! BE4-135 | Ved | Alcatel & TCL Old Models | 3 | 07-13-2001 07:38 |
Still dont understand way FF00 | Format1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 02-12-2001 10:23 |
