10-15-2001, 17:33 | #1 (permalink) |
No Life Poster Join Date: Jul 2001 Age: 42
Member: 5184 Status: Offline Thanks Meter: 246 | emmulating dejan box get soft alca dongle emmulator<br />put it into flasher directory <br />run emmu<br />go to function <br />enable capture<br />minimize the emmu window<br />connect your box<br />run nk_fl 104<br />let the red light in the right lower corner<br />of you screen turn to green <br />it meens that data has been copied to emmu buffer<br />enlarge emmu window<br />go to function<br />disable capture and get data <br />now buffer will be full of data<br />go to file<br />save as ex.dejanbox.kpe<br />after that disconnect your box <br />open alca emmu <br />go to file <br />open file ex.dejanbox.kpe<br />go to function <br />enable emmulator<br />minimize window <br />run nk_104<br />connect your simple dejan cables lpt<br />see what happens <br />no box needed?<br />working ok?<br />if so then mail me your saved dejanbox.kpe file dongle emmulation is just another way<br />happy trying box owners. |
10-15-2001, 18:23 | #5 (permalink) |
Member: 5184 Status: Offline Thanks Meter: 246 | if you get the hardlock <br />maybe YES<br />THE PURPOSE OF THIS IS TO COPY HARDLOCK INFO<br />AND EMMULATE IT and send free copy of the files<br />you have professional software to do<br />the job<br />but it requires external hardware<br />this will decrypt all known formes of <br />hardlock protection keys<br />and emmulate them thanks to u.c |
10-16-2001, 01:10 | #7 (permalink) |
No Life Poster Join Date: Dec 2000 Location: UK
Member: 2868 Status: Offline Thanks Meter: 514 | Hi Boga<br />The solution you offer is for some kind of dongles. Well I am not friendly with that stuff, but I am 100000 % sure that this will not work.<br />Why?<br />The box IS NOT A DONGLE !!!!!<br />Just imagine that you have one program, and you decide to split it in two. One of the parts stays in the PC, and the other part is hardware implemented on the LPT port. The part which stays on the PC is responsible to give the information to the hardware implemented part for calculation.<br />Dejan is good, but not ***. He just uses a microcontroler with hardware code protection for the second part of the program.<br />Well I do not know how to scan functions with 2 arguments (16 byte header from the PPM file and MSID).<br />Good work from Dejan<br />Best regards<br />Daniel |
10-16-2001, 10:53 | #8 (permalink) |
Junior Member Join Date: Sep 2001
Member: 6555 Status: Offline Thanks Meter: 0 | In fact cracking the Dejan Box is not that hard for any one have the box. But the simple secret it is not cracked till now that, the owner of the box bought it too expensive and he want to get his money back, so no one want to help in cracking it.<br />I think the following may work:<br />- Stop the functions that read the parameters from box and increment the number of phone flashed.<br />- After every successful update operation and before eeprom update command executed, save the Flash Authorization ID. Repeat it to save all FAID of all phones and build a FAID library like the ones of the partial flashes used to unlock phones.<br />- Modify the dejan 1.04 software to get another one access the mobile through MBUS not the box (I already made this modifications and it working fine).<br />- Modify also the software so it just read the FAID from file and not from the Box then it send the update command to the phone through MBUS.<br />- Finally any one want to upgrade will use Dejan 1.00 to flash the mobile then use the modified dejan 1.04 + the FAID file to just update the eeprom of the phone. Any way, myself I don't like crack. I know Nokia employers have families, but I also don't like that Dejan and other people steal Nokia and enjoy it forever. |
10-16-2001, 14:03 | #9 (permalink) |
Member: 5184 Status: Offline Thanks Meter: 246 | ho i forgot to mention that connection <br />cables to lpt will be different<br />a little experimenting will do<br />pro emmulators with hardware are fully <br />functional with all parallel and series<br />schemes<br />so if your problem is dongle plus phone <br />connection all in one <br />then thats no problem <br />because the pro hardware is a pci slot board<br />with usb. parallel. serie .firewire<br />no dongle to read info?<br />well the software includes a multi algorithm<br />brute force attack method<br />make what you whant of it <br />ripp dongles ripp multi protection boxes<br />and service boxes whatever.<br />you will find this product for sale <br />around the net.<br />when you see the board you will understand |
10-18-2001, 19:38 | #10 (permalink) |
Freak Poster Join Date: Jun 2000 Age: 45
Member: 1528 Status: Offline Thanks Meter: 10 | Dejan box is not only dongle. it has 3 functions:<br />1. mbus datacable<br />2. dongle for calculating faid<br />3. flasher Communication is not always the same. So it's not so esasy to emulate it. I want to make pic based emulator but don't know the schematic. And second problem is how to calculate faid. |
10-18-2001, 21:02 | #11 (permalink) |
Freak Poster Join Date: Apr 2001 Location: uk
Member: 3995 Status: Offline Thanks Meter: 0 | Hi mOp,how are you,havent heard from you from last e-mail you sent.I sent one back to you i dont no if you got it but if you have new e-mail please e-mail me.By the way can you please e-mail me the above file because i cannot download it... ALL THE BEST MY FRIEND........... =====DEAD MAN INC=====<br /> <img src="biggrin.gif" border="0"> <img src="biggrin.gif" border="0"> <img src="biggrin.gif" border="0"> <img src="biggrin.gif" border="0"> |
Bb5 Box, Mt-box Lite, Dejan Box,uid Box | kwamena | Nokia Base Band 5 ( BB-5 ) | 37 | 11-10-2007 17:31 |
dejan box 1.5 or dejan box 1.5 pic now for sell best price GSMNL1 | =GsMnL1-TeAm= | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-19-2002 19:16 |
windls / dct3 workshop / dejan 1.5 working with dejan box but ddp 2.4 not | mobidoc | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 02-08-2002 12:28 |
Can DCT3 box or Dejan box handle new versions and new 5510 effortlessly?? | Chaku | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 11-04-2001 19:44 |
Dejan Box 1.02 vs Box 1.04 | ed2k_7 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 10-18-2001 19:35 |
