11-07-2002, 17:29 | #1 (permalink) |
Junior Member Join Date: Nov 2001 Location: Sampaloc
Member: 7545 Status: Offline Thanks Meter: 0 | Flash erase check (battery voltage too low) the phone is 3310, it used to be "contact service" and when i check through wintesla, it's the eeprom tune checksum that has problem. however, if i flash virgin eeprom to the phone, it displays something like the loader is not correct but if i change mcu-ppm, it writes smoothly. i tried to reheat flash ic thinking that it might be a connection problem but after that, the flasher already displays "battery voltage too low" even if the battery is fully charged and even if i put a regulated power supply to the phone. do you have any solution to this? BR |
11-08-2002, 07:53 | #4 (permalink) |
No Life Poster Join Date: Jan 2002 Location: MARS
Member: 8304 Status: Offline Thanks Meter: 362 | I suggest you flash a full backup from working phone.If you still get battery low message then re-heat ccont and try again,also check battery contacts are o.k |
11-08-2002, 17:04 | #5 (permalink) |
Member: 7545 Status: Offline Thanks Meter: 0 | i'm sorry for multiple posting because i thought that this is both hardware & software problem... next time... @ feverdj I used rolis. when i use knok flasher, it displays "cannot prepare phone". i also used nlicker but no good |
8250 flash erasing error(battery voltage is too low) | gama_cell99 | Nokia Hardware & Hardware Repair | 8 | 06-01-2005 17:09 |
8250 flash erasing error(battery voltage is too low) | gama_cell99 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 05-23-2005 06:01 |
3310 flash erasing error (battery voltage is too low) | pana_java | Nokia Hardware & Hardware Repair | 2 | 04-04-2005 14:46 |
6210 flash erase check | pali | Nokia Hardware & Hardware Repair | 1 | 03-17-2005 01:25 |
Flash erase check (battery voltage too low) | scanner | Nokia Hardware & Hardware Repair | 4 | 11-11-2002 17:29 |
