Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L )
Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) Nokia Legacy Models Like 1011, 1610, 211x, 2x20, 6050, 3110, 8110, NKxxx , 2100, 3210, 3310, 3330, 3410, 5110, 5210, 5510, 6110, 6150, 6210, 6250, 7110, 8210, 8250, 8850 also 9110 & 9210
Old 11-23-2001, 13:56   #1 (permalink)
Member: 7444
Sonork: 100.99999
Thanks Meter: 10,008
Post FlashBOX Modified by VsH-GsM
Whats new:<br />-automatic Start&End address writing in read flash section<br />-new nokia phones added<br />-a lot of flash loaders & boot loaders corrected<br />-full flash & mcu & ppm addresses added to program<br />-some tools added<br />-three bugs fixed
download it : <br /><a href="ftp://ftp.noetec.at/nokia/PROGS/FlashBOX.zip" target="_blank">ftp://ftp.noetec.at/nokia/PROGS/FlashBOX.zip</a>
Old 11-23-2001, 14:16   #2 (permalink)
Member: 3153
Thanks Meter: 2
Post
wow that was quick ..
thanks for the upload, and making it opublic .. <br />you DA man !!
Mick ...
Old 11-23-2001, 14:33   #3 (permalink)
Member: 4274
Thanks Meter: 18
Post
link is down... i'll try later...
Old 11-23-2001, 14:35   #4 (permalink)
Member: 5492
Hi!
I can't suck from that FTP!!
please try to upload somewhere other!
thx, cu
Old 11-23-2001, 15:21   #5 (permalink)
Member: 3075
Thanks Meter: 2
Arrow
- For all here: <br /><a href="http://www.terra.es/personal4/nkmont/test.htm" target="_blank">Landy´s page</a>
BR Landy.- <img src="eek.gif" border="0">
Old 11-23-2001, 16:02   #6 (permalink)
Member: 4812
Post
i'm working in a modification too...
i have install your EXE but Flash box don't start...
some problem in your code i think...
Old 11-23-2001, 16:10   #7 (permalink)
Member: 7395
Post
hey .<br />wanderful.<br />mm by the way i want to wite some for my problem.<br />i flashed my phone 5110 from 0020000-0040000 just for education.(it is tru you cannot have knowledge if you don't **** your phone at the beginning)):<br />anyway and there was CS .i flashed it again with original %100 working flash.bun to lıck.<br />it is said to me that there can be a problem with the eeprom (24c16).so i downloaded ponyprog.and epromunlocked.(but i cannot find eeprom burner):<br />there is sheme with eeprom unlocked is there any1 tried this.<br />if i made a mistake bye to phone.<br />thanks<br />(i can read it normally with nokiatool)
Old 11-23-2001, 17:00   #8 (permalink)
Cheater -Don't Deal with him-
Member: 7250
Sonork: 100.1575042
Thanks Meter: 440
after install setup file,dont work.<br />whats prob????
Old 11-23-2001, 17:41   #9 (permalink)
Member: 7444
Sonork: 100.99999
I and my some friends tested it and it has not any problem!<br />This program doesn't tested in Win2000/XP.<br />what error you got?<br />i have these runtime files in my system directory (IN WINDOWS ME) and the "FlashBOX.exe" successfully working:<br />-------------------------------<br />COMCTL32.OCX (VER:6.0.80.22)<br />DAO350.DLL (VER:3.51.1608.0)<br />FLASHBOX.DLL<br />MSCOMCTL.OCX (VER:6.0.88.62)<br />MSVCRT40.DLL (VER:4.22.0.0)<br />RICHED32.DLL (VER:5.0.1461.82)<br />MSVBVM60.DLL<br />-------------------------------<br />VB5DB.DLL (MAY BE NEEDED)<br />VBAJET32.DLL (MAY BE NEEDED)<br />MSRD2X35.DLL (MAY BE NEEDED)<br />MSREPL35.DLL (MAY BE NEEDED)<br />EXPSRV.DLL (MAY BE NEEDED)<br />MSJET35.DLL (MAY BE NEEDED)<br />MSJINT35.DLL (MAY BE NEEDED)<br />MSJTEY35.DLL (MAY BE NEEDED)
Old 11-23-2001, 17:54   #10 (permalink)
Member: 7444
Sonork: 100.99999
Hi!<br />I found a little problem in FlashBOX Setup :<br />you should not run FlashBOX from start menu after installing!<br />please run it from:<br />\Program Files\FlashBOX\flashbox.exe
Good Luck!!! <img src="biggrin.gif" border="0"> <img src="biggrin.gif" border="0"> <img src="biggrin.gif" border="0">
Old 11-23-2001, 19:14   #11 (permalink)
pks
Member: 3815
Thanks Meter: 2
Post
flashbox original/modified doesnt run on windows 2000. got the error message:
flashbox.exe has generated errors and will be closed by Windows. You will need to restart the program. An error log is being created.
is there anyway of modifying it so that it WILL run under windows 2000?
vhs-gsm, how about you release your modified source code as well? <img src="smile.gif" border="0">
Old 11-23-2001, 19:38   #12 (permalink)
Member: 7444
Sonork: 100.99999
hi pks!<br />send me error log please.<br />my mail : [email protected]
Old 11-23-2001, 19:45   #13 (permalink)
Member: 1180
Post
Here is my experience with Ice Dragon's FlasherBox:
I installed the setup.exe. I ran it from the start menu. Doesn't launch! I launched it from the directory c:\programmes Files\flashbox.. Doesn't work. I created a directory c:\flashbox and copied all the files in the c:\programmes Files\flashbox directory into it and ran it from c:\flashbox. It works. Tested a 3310. I can read the phone. I unistalled the soft and kept the c:\flashbox directory. Doesn't work. I reinstalled it. it works but only from c:\flashbox. That's all. Hope this helps.
Old 11-23-2001, 19:50   #14 (permalink)
Member: 7444
Sonork: 100.99999
Post
These are screenshots of program:
[img]ftp://ftp.noetec.at/nokia/splash.jpg[/img]
[img]ftp://ftp.noetec.at/nokia/prog.jpg[/img]
TRY IT!!! <img src="smile.gif" border="0">
Old 11-23-2001, 20:05   #15 (permalink)
Member: 7444
Sonork: 100.99999
Post
if you have all of this files in your system directory,you wont have any problem.<br />[img]ftp://ftp.noetec.at/nokia/files.jpg[/img]
Thanks for your trying & reporting problems <img src="biggrin.gif" border="0">
FlashTONE Cracked by VsH-GsM VsH-GsM Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 32 03-26-2002 13:15
T20 & A2618 Service by VsH-GsM ***FREE*** VsH-GsM Old Ericsson Phones & Sony Phones 23 02-02-2002 00:50
WinDLS 2.4 CRACKED by VsH-GsM ***FREE*** VsH-GsM Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 45 02-01-2002 04:41
Nokia DCT4 Flasher by VsH-GsM VsH-GsM Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 33 01-27-2002 17:54
Nokia Partial Maker by VsH-GsM ***FREE*** VsH-GsM Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 12-31-2001 13:35
Page generated in 0.59610 seconds with 8 queries
