03-09-2002, 09:24 | #1 (permalink) |
Major Poster Join Date: Dec 2001 Location: Canada
Member: 8015 Status: Offline Thanks Meter: 0 | flasher cable <-> MBUS only cable? So if I short white and blue wires I should get a MBUS only cable right? But will shorting these two wires work as flashing cable too? I opened the adapter and was trying to short those two pins with a aluminium foil (because I don't want to screw up the wires) and it doesn't work. I guess I didn't do it properly. I was thinking just to cut out those two wires =P but no, I still want it as it was. What is a good way to short the wires/pins so I can still have the adapters for flashing. |
03-09-2002, 10:18 | #2 (permalink) |
Freak Poster Join Date: Feb 2000 Location: Bristol - UK
Member: 1034 Status: Offline Thanks Meter: 0 | Short the pins on the COM cable:D I did mine by cutting the end of a manual switch cable and soldering to a db-9 connector and the using an old serial to ps2 mouse converter. It should be quite easy to work out the pins, I haven't got mine here so I can't check. Works a treat! |
03-09-2002, 11:54 | #3 (permalink) |
Member: 8015 Status: Offline Thanks Meter: 0 | So you mean by modifying the cable instead of the adapters. It's a good idea and I think I need to find a PS/2 cable first. I am looking at a diagrams about the PS/2 male and female connectors but I am not sure if they are right. The pins are like inverted for male and female connectors... I assume they are right? I am looking at http://gsmsearch.com/faq/nokiaflasher.html |
03-11-2002, 07:52 | #5 (permalink) |
Member: 8015 Status: Offline Thanks Meter: 0 | thanks. I tried it but the MBUS cable that I mde only works on logomanager (with MBUS setting) and nokiatool035 but not in nk_calc or rolis 1.5b tried the same phone (8290) with the self made cable, no luck. But with another M/FBUS mannual switching cable works fine without external power... ??? do I need to worry about what goes to the Tx and Rx of the phone? because I cut out the Tx,Rx and MBUS in the cable. combined Tx and Rx to MBUS of the phone. Nothing to Rx or Tx to phone.... And MBUS = M2BUS? PS the cable I am modifying is a flasher cable with PS/2 adapter. |
SMTi <--> SCDR-II cables | gumoff | SMTi | 3 | 07-06-2009 11:04 |
mt-box cables <--> j.a.f./universal adapter | gumoff | Nokia Base Band 5 ( BB-5 ) | 0 | 11-28-2008 14:22 |
YEAH BEYOND THE LIMITS... Qtek 8080 <-> SPV E200 <-> I-Mate SP2 | PYCON | HTC & PDA WM( With Touchscreen) | 6 | 04-28-2006 02:00 |
Schematics for adaptor 4in1 <-> UFS cables | twisterfan | Samsung (USB-Smart) | 0 | 03-30-2006 16:58 |
WANTED: Sonyericsson connector with wire, USB cables or sonyericsson <-> USB cables | Mizar | Wanted Products | 1 | 06-25-2004 11:53 |
