03-07-2002, 02:42 | #1 (permalink) |
Freak Poster Join Date: Mar 2002 Location: uk Age: 44
Member: 9990 Status: Offline Thanks Meter: 2 | Has anyone put together any dct-3 tutorials ?? b-phreaks etc... Does any one know if there has been a tutorial written about using the above programmes to upgrade software versions, calculate authority id, imei repair etc... all help appreciated. |
03-07-2002, 03:20 | #2 (permalink) |
Freak Poster Join Date: Apr 2001 Location: France Age: 41
Member: 3981 Status: Offline Thanks Meter: 0 | Hi Guy, try to read the maximum of topic about dtc3 phones, and ask here a question not for a tutorial, because nobody will answer your request if you do that. Good Luck |
03-07-2002, 03:34 | #4 (permalink) |
Member: 9990 Status: Offline Thanks Meter: 2 | ok cheers boyz, this is what i have gathered so far. you flash ppm + mcu using lpt flasher cable and rolis 4.77 for example, you then connect phone to b-phreaks eeprom 3.00 , click on the first icon from the left whcih calculates authority id, and the phone should be up and running. To unlock you just click on padlock on b-phreaks and this resets lock back to factory set. please correct me if im wrong. |
03-07-2002, 05:04 | #5 (permalink) |
Member: 3981 Status: Offline Thanks Meter: 0 | It's ok you can do like that, I use a different method, i like to keep old method which work, so I flash phone with new mcu+ppm, then i make a log with b-phreaks logger 1.6, then i calculate Authtority Id with Faid, then i update the new log with b-phreks 1.6. I hope that it can help you. To flash i use ****** 7.3, it seems to be a good software. Good Luck |
03-07-2002, 05:11 | #6 (permalink) |
Member: 9990 Status: Offline Thanks Meter: 2 | do you think you could give me links to : b-phreaks logger 1.6, and ****** 7.3. when you say "you calculate authority id with faid" is this a seperate programme or built in on b-phreaks lgger i.6 or the 3.0 version. where is the best site for mcu+ppm ?? sorry for being so puzzled |
03-09-2002, 13:28 | #9 (permalink) |
Freak Poster Join Date: Jan 2002 Location: ME
Member: 8400 Status: Offline Thanks Meter: 0 | try this , maybe this helps - http://gsmsearch.com/faq/nokiaflasher.html |
Has anyone easy way to remove metal plate of AF51 etc? | jeanfleur | E-Gold Based Phones | 3 | 10-31-2006 19:06 |
Java midlet dct-3,dct-4 etc | gsm2k2 | Java, iOS, Android, Symbian development | 7 | 05-04-2004 12:13 |
DCT-3 IMEI Calc software - Does anyone have it FREE?? | unlockgod | Nokia Multimedia | 31 | 12-07-2003 11:01 |
Few lines of VB source required to read DCT-3 IMEI anyone? | Nick-A | GSM Programming & Reverse Engineering | 3 | 07-21-2003 18:58 |
has anyone tested griffin DCT-4 flasher??? | masterross | Nokia Digital Core Technology 4 ( DCT-4 ) | 36 | 07-17-2002 21:50 |
