Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L )
Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) Nokia Legacy Models Like 1011, 1610, 211x, 2x20, 6050, 3110, 8110, NKxxx , 2100, 3210, 3310, 3330, 3410, 5110, 5210, 5510, 6110, 6150, 6210, 6250, 7110, 8210, 8250, 8850 also 9110 & 9210
Old 08-05-2001, 20:19   #1 (permalink)
Member deceased !!
Member: 4983
Post Help with a 3210 problem, pse ...
Hi all..<br />I have received a 3210 unit than have a problem (was flashed wrong).<br />Its say v 6.0 and when power up without sim card, it power ok, and tell insert sim<br />I insert sim and then power up, but on the screen do not shown any letter, is blank.<br />I checked with nokia tools and see there are 2 IMEI numbers.<br />I try to flash it and situation is the same.<br />Any good solution pse ?<br />TNX in adv
Regards <br />Kilowat
Old 08-06-2001, 00:10   #2 (permalink)
MDR
Member: 1272
Post
2 imei mensa corrupted eeprom
desolder and repair by bartek
Old 08-06-2001, 00:59   #3 (permalink)
Member deceased !!
Member: 4983
Post
Can explain how do it ?<br />TNX in adv
Kilowat
Old 08-06-2001, 16:45   #4 (permalink)
boganice's Avatar
Member: 5184
Post
get solder iron desolder eprom<br />24c128<br />read content with eprom programmer<br />make backup <br />run contact service 1.2 bartek<br />open eprom backup <br />select phone 5.31,,5.36 or 6.00<br />select repair phone<br />save it to any folder<br />program it back to eprom<br />solder eprom<br />thats it<br />should work.
other solution <br />get full backup of working phone same version<br />start adress 200000...600000<br />and flash it
Old 08-06-2001, 22:12   #5 (permalink)
Member deceased !!
Member: 4983
Post
Hi Boga, tnx for the info...<br />The second solution you tell is also ok ?? Have tested it ??<br />Need to be a full flash from the same opeartor ?<br />Second option is very easy, will try if tell me is ok
Regards<br />Kilowat
Old 08-06-2001, 22:29   #6 (permalink)
Member deceased !!
Member: 4983
Post
Boga, the second solution you tell, will solve the double IMEI ?
WAit your news to test it.
Old 08-07-2001, 23:26   #7 (permalink)
Member deceased !!
Member: 4983
Post
Boga <br />I tested the second solution you tell and do not work, phone is in the same situation
Any idea ?
need help with network 3210 ZetMen Nokia Hardware & Hardware-Repair Area 0 03-05-2004 13:56
Please Help with "Contact Provider" Problem ab1009 Mitsubishi 7 07-06-2003 16:37
pls help with r310 charge problem .::AkhavanGSM::. Old Ericsson Phones & Sony Phones 0 10-24-2002 17:04
PLEASE help with 8210 charge problem HooGSM Nokia Hardware & Hardware-Repair Area 1 05-24-2002 00:41
Pleas Help with my 3210 Format1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 03-22-2001 10:24
Page generated in 0.63912 seconds with 11 queries
