Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L )
Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) Nokia Legacy Models Like 1011, 1610, 211x, 2x20, 6050, 3110, 8110, NKxxx , 2100, 3210, 3310, 3330, 3410, 5110, 5210, 5510, 6110, 6150, 6210, 6250, 7110, 8210, 8250, 8850 also 9110 & 9210
Old 06-23-2000, 04:47   #1 (permalink)
Member: 719
Exclamation help! contact service 5.28 5110!
is there a way to remove contact service using wintesla? or anything? pls pls pls
Old 06-23-2000, 05:37   #2 (permalink)
X-Shadow's Avatar
Member: 871
Thanks Meter: 601
Post
Hello Koloksy,
Did you make backup of EEPROM before trying
to work with the unit? If so, just restore
the backup and all will be ok. If you didn't
make backup, you're gonna have a very hard
time. You might get your phone to power on
with the menus and stuff, but you will not
get signal from any provider because some
inforamtion are not right in your EEPROM.
How did this happen?
Best Regards,
X-Shadow
Old 06-23-2000, 11:59   #3 (permalink)
Member: 719
Post
hi,
i did restore backup of eeprom but still in contact service. i attempt trying eeprom solution but no luck, repeat process then try again until no. 4 and contact service.
after that, batt. became hot and i immediately remove it, good thing there wasn't any smell
i will unlock again, this time attempt flash solution for it, hope i don't break it's pins
Old 06-23-2000, 16:43   #4 (permalink)
Member: 827
Unhappy
A heating battery?
Seems to me that the chip is damaged!
tsk, tsk, tsk... we should not really mess with the hardware. Do you know that ESD might have damaged the chip? It's one problem that's hard to avoid since it happens even if no obvois misshandling is done. And it happens very very quick.
Originally posted by koloksky:
hi,
1600b NET10I h RH65 need help to get rid of " CONTACT SERVICE 5 " Unlockemall Universalbox 15 02-03-2011 18:00
Nokia 1600B - Contact service 5 pls. help... Joda Nokia Hardware & Hardware Repair 1 08-29-2009 19:59
Rh-65 1600b V.5.01 Unlck And Contact Service 5 ? johansel Universalbox 2 12-06-2007 05:43
" CONTACT SERVICE " on 5110 v 5.29 because of unlocking Razvan Chirica Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 09-08-2000 09:29
need help in unlocking 5.28 with unfamiliar eeprom!!! Satanael Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 08-15-2000 07:14
Page generated in 0.25230 seconds with 8 queries
