03-26-2001, 18:07 | #1 (permalink) |
Freak Poster Join Date: Jun 2000 Location: laguna,philippines Age: 48
Member: 1544 Status: Offline Thanks Meter: 1 | about dark flasher shell how can i make dark flasher shell work... every time i click on something... it always says "error 53" file noy found?? help please.... |
03-27-2001, 19:38 | #5 (permalink) |
Freak Poster Join Date: Dec 2000 Location: Portugal
Member: 2785 Status: Offline Thanks Meter: 0 | download all the files from www.crosswinds.net/~darklemming except for the html and the jpg. extract darflashershellXXX.zip to any directory you like. lets take, for example, 'C:\darklemming' next unpack the 3210_partial into the directory you just created. be sure to unpack it to c:\darklemming and not c:\darklemming\3210_partial. do not unpack into partial DIR either, cause the zip files have path info. do the same thing for all the other XXXX_partial.zip files and unpack the dependency files (DLL, OCX and TBL) to your system DIR. if this cannot help you guys, i sugest you buy a new PC, cause my shell is working on every PC i've tryed... regards Dark Lemming |
03-29-2001, 09:44 | #7 (permalink) |
Member: 2785 Status: Offline Thanks Meter: 0 | you mustn't install the program in win2k or winME/98 if you don't have all permitions. check that you can write to all directories. i can't help you further since i never experienced this kind of error before |
03-29-2001, 17:24 | #9 (permalink) |
Member: 1544 Status: Offline Thanks Meter: 1 | im using it in windows me... maybe thats the problem.... im using pentium III 1000... anyway thanks alot... maybe i should try a different shell.. thanks dark for explaining.... more power.. |
04-01-2001, 03:43 | #12 (permalink) |
No Life Poster Join Date: Feb 2001 Location: Portugal
Member: 3302 Status: Offline Thanks Meter: 16 | hi, I use a lot this prog by dark... but sometimes it gives me that same error... i just close prog and restart it and the error is gone! It happens sometimes with a few versions of 3310 and 7110... Regards, KiCK |
04-01-2001, 17:45 | #13 (permalink) |
Member: 1544 Status: Offline Thanks Meter: 1 | dark flasher shell is now working with me... i rename all my partial flash to phone-version.fls i put it manually to partial folder... nk_files have no fls files... but i think there is something wrong... every time i flash a phone... i have to delete the fls in the nk_folder manually so that it will work again? strange... |
AT LAST: Dark Flasher Shell 2 arriving | Dark Lemming | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 13 | 07-07-2001 18:35 |
Dark Flasher Shell 1.44 | Dark Lemming | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 19 | 05-21-2001 22:52 |
about dark flasher shell? | rothmanns | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-27-2001 15:26 |
about dark flasher shell | rothmanns | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 03-27-2001 15:15 |
dark flasher shell - a new shell around | Dark Lemming | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 20 | 03-07-2001 13:48 |
